Forum Archive Home -> ffmpegX general discussion -> flvtool for Metadata stopped working, any ideas why?
flvtool for Metadata stopped working, any ideas why? | ||
| todaynet posted 2009 Oct 12 21:15 | ||
| I have used ffmpegX several times to encode MOV files as FLV. I have installed the flvtool and it was adding metadata to the converted files without any trouble for a while. All of a sudden (no system changes etc.), it is failing. I've re-installed everything, no luck. There log reports...
video:11743kB audio:5265kB global headers:0kB muxing overhead 29.040135% bench: utime=40.600s ERROR: ERROR: /Library/Ruby/Site/1.8/flv/stream.rb:489:in `eof?' ERROR: /Library/Ruby/Site/1.8/flv/stream.rb:489:in `eof?' ERROR: /Library/Ruby/Site/1.8/flv/stream.rb:55:in `initialize' ERROR: /Library/Ruby/Site/1.8/flvtool2/base.rb:272:in `new' ERROR: /Library/Ruby/Site/1.8/flvtool2/base.rb:272:in `open_stream' ERROR: /Library/Ruby/Site/1.8/flvtool2/base.rb:205:in `process_files' ERROR: /Library/Ruby/Site/1.8/flvtool2/base.rb:44:in `execute!' ERROR: /Library/Ruby/Site/1.8/flvtool2.rb:168:in `execute!' ERROR: /Library/Ruby/Site/1.8/flvtool2.rb:228 ERROR: /Applications/ffmpegX.app//Contents/Resources/flvtool2:2:in `require' ERROR: /Applications/ffmpegX.app//Contents/Resources/flvtool2:2 Encoding completed on Mon Oct 12 20:07:38 MDT 2009 I have re-run the ruby setup routine for flvtool a couple of times, no change. Any suggestions? | ||
| Case posted 2009 Oct 15 12:22 | ||
| The path that is mentioned in the error lines does not make sense to me. Ruby and flvtool2 should not be in /Library for Mac OS X 10.4 or 10.5. Not sure about 10.6...
Mac OS X 10.5.8 /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/bin/flvtool2 Mac OS X 10.4.11 /usr/bin/flvtool2 | ||
| drasw posted 2009 Nov 06 07:57 | ||
| I just downloaded to software and it converts form mov to flv beautifully. Now I can use some help with the flvtool2. I opened terminal, then new command, then typed in cd and dropped in the unzipped folder called -1.0.6 and hit enter - perfect. The I opened new command again typed in and typed in ruby setup.rb config and hit enter and I got a -ruby: No such file or directory -- setup.rb (LoadError). Any thoughts? | ||
| Case posted 2009 Nov 06 11:34 | ||
Login/Register to our forum to be able to post here.
