Forum archive - Firmware problems panasonic dmr ez 27
http://www.supermediastore.com/
Forum Archive Home -> DVD Recorders -> Firmware problems panasonic dmr ez 27
rick09 posted 2009 Sep 27 13:43
During a firmware instalation my DVD went off, now it displays "00000", is there a way to do a factory reset or a way to fix this problem
jjeff posted 2009 Sep 27 14:59
While the machine is powered on you want to hold down both the CH up and CH down (on the main unit) for at least 5 seconds.
This will do a factory reset, but if you're firmware is corrupted I'm not sure if it's going to help you.
Note I've read you want to burn firmware updates to CDs and not DVDs, not sure if this could have caused your problems?
rick09 posted 2009 Sep 28 09:43
:) thanks...alerady done it and did not work, by the way the firmware as burned into a CD...
Any other suggestion/advice on how to fix it will be apppreciated...
jman98 posted 2009 Sep 28 10:53
If you can find an older version of the firmware you can try to load that, but if you lost power during a firmware upgrade, sometimes the player is destroyed. That is one of the risks that can happen during firmware upgrades - if the upgrade is interrupted, the upgrade will be corrupted and it can make the player useless. You could try to get the player repaired and get new firmware in it, but that will probably cost as much as a new player.
rick09 posted 2009 Sep 28 11:31
thanks, any idea of where to find and older version of the firmware
Login/Register to our forum to be able to post here.
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
