Forum Archive Home -> SVCD2DVD & VOB2MPG -> finished processing with no files
finished processing with no files |
| l4l4u posted 2009 Oct 09 17:04 |
I used vob2mpg v3.0 many times before, last time i try i have this problem:
The program not create a log file..... I try the version 2.5 with same problem, but this time was created a log: ******************************************************************** ************************ SYSTEM INFORMATION ************************ ******************************************************************** ***************************** VOB2MPG ***************************** Name: VOB2MPG Title: Version: 2.5.0.0 Executable: H:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe Executable size: 460 KB Executable size in bytes: 471040 Executable CreationTime: 1/1/2000 00:00:00 Executable LastWriteTime: 1/1/2000 00:00:00 Executable LastAccessTime: 1/1/2000 00:00:00 ****************************** Drives ******************************* **********************UNABLE TO GET SYSTEM INFO******************* ********************** Input Folder ******************* 18:49:56: Volume in drive Z is DVD_VR 18:49:56: Volume Serial Number is 4DD7-862D 18:49:56: Directory of Z:\ 18:49:56: 03/01/2006 22:12 <DIR> VIDEO_TS 18:49:56: 03/01/2006 22:12 <DIR> VIDEO_RM 18:49:56: 0 File(s) 0 bytes 18:49:56: 2 Dir(s) 0 bytes free 18:49:56: Z:\> ********************** Output Folder ******************* 18:49:56: Volume in drive P is LAU HD EXTERNO 1TB (1) 18:49:56: Volume Serial Number is 1887-5BDD 18:49:56: Directory of P:\124 18:49:56: 09/10/2009 13:21 <DIR> . 18:49:56: 09/10/2009 13:21 <DIR> .. 18:49:56: 0 File(s) 0 bytes 18:49:56: 2 Dir(s) 227.992.981.504 bytes free 18:49:56: P:\124> I already try change the source and destination, with no results Sry my english, and thx in advanced |
| ChrissyBoy posted 2009 Oct 10 01:21 |
| Can you take a look at
http://forum.videohelp.com/topic373834.html and see if you also have a WMI issue. |
| l4l4u posted 2009 Oct 10 15:12 |
| thx for reply...
yes, before i post here, i already try... anymore ideas? |
| ChrissyBoy posted 2009 Oct 11 03:23 |
| Do you mean you have the same issue with WMI and System Info? |
| l4l4u posted 2009 Oct 11 19:53 |
| yes, is the same problem with wmi, but that solution didnt work for me... |
| l4l4u posted 2009 Oct 12 19:03 |
| anymore ideas? |
| ChrissyBoy posted 2009 Oct 15 02:35 |
| A few links that may help:
http://windowsxp.mvps.org/repairwmi.htm http://howmakeyourself.blogspot.com/2009/07/how-to-repair-windows ... ement.html http://www.pcreview.co.uk/forums/thread-531758.php |
Login/Register to our forum to be able to post here.
