Forum archive - ffmpegX.dmg.part? :(
http://www.supermediastore.com/
Forum Archive Home -> ffmpegX bugs and suggestions -> ffmpegX.dmg.part? :(
CoriMariee posted 2007 Mar 01 16:20
I tried to download ffmpegX.dmg onto a OSX 10.4.8 ibook G3, but when I began to download, the computer displayed both an icon for ffmpegX.dmg and then an excel document called ffmpegX.dmg.part. When the download is finished, it says it cannot finish it because it can't find the source code for the excel doc., which I don't think is supposed to be there anyway. Can someone tell me what I'm doing wrong? I don't have an intel MAC yet, so I'm still running on PPC. Can anyone help? I really want to be able to use this program.
Ai Haibara posted 2007 Mar 01 18:15
I'm guessing you're using Firefox to download ffmpegX.dmg.
I've seen Firefox do that while it's downloading. It will allocate both the correct filename and another file with an additional .part extension - that's the incomplete, downloading file, and will (should) be deleted when the download is finished. Don't worry about it, if that's the case. :)
CoriMariee posted 2007 Mar 01 19:47
Yes I am using Firefox, good catch. :D It didn't allocate them and the file won't open. :(
CoriMariee posted 2007 Mar 01 21:00
Ok, used explorer to download, but am now having trouble with the mpeg binary, I think it's intel, can I use the old one?
Ai Haibara posted 2007 Mar 01 23:15
By 'allocate,' I meant that both filenames will be created in the folder that you're saving the file to. In this case, you would see the following:
"ffmpegX.dmg" - Empty file, while the actual ffmpegX.dmg is being downloaded. Once it's finished downloading, the actual file will replace the 'empty' file.
"ffmpegX.dmg.part" - The actual ffmpegX.dmg file as it's being downloaded, and incomplete. Once the download is complete, this will replace the above file, and is normally deleted. You won't normally have to worry about opening the .part files.
CoriMariee :
What problem are you experiencing? Any specific error messages?
I believe the components offered on the ffmpegx download page are universal binaries, if I remember correctly, and should work on a PPC system as well as an Intel Mac.
CoriMariee posted 2007 Mar 02 01:03
The browsers don't know how to handle the file. I've tried, Firefox, Safari, Explorer and Navagotor and I end with a bunch of numbers and symbols :(
Ai Haibara posted 2007 Mar 02 01:12
Right-click (or CTRL-click) on the link and select the option to save the file/link, rather than click on the link normally. In Firefox, the one you want to choose should be "Save Link As...", I believe.
(It's also described on the ffmpegx download page as the following:
The mpeg2enc binary for ffmpegX 0.0.9x is available here (don't click but use CTRL-click on link and then "Download link on disk").
CoriMariee posted 2007 Mar 02 10:11
It still won't recognize it. I tried downloading it to disk, any other suggestions? I really appreciate your help :) :)
Ai Haibara posted 2007 Mar 02 14:34
Are you still having trouble downloading mpeg2enc.intel, or do you have a copy of it saved to your hard drive?
If you have it saved to disk, don't run it directly. Try following the directions on http://www.ffmpegx.com/download.html , under How to install:.
pitmanj posted 2007 Dec 16 10:27
i have downloaded it but can't open it how can i get through this please help me
Ai Haibara posted 2007 Dec 16 13:10
Are you trying to open the 'ffmpegX.dmg.part' file? That should be an incomplete or downloading file, if you're using Firefox as well. (I'm not sure offhand if Mozilla/Seamonkey or Camino also do this.) Let the download finish, and then try opening/mounting the 'ffmpegX.dmg' file.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
