Forum archive - Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
http://www.supermediastore.com/
Forum Archive Home -> Video Conversion -> Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
TheViking posted 2009 Nov 04 07:12
I'm trying to convert an avi file to PSP format. I use XVID4PSP as many times in the past with great success. However, with quite a large bunch of files now, I get this error:
"Could not open AAC encoder"
I find this very strange and cannot see any reason why these files would give an error (as opposed to the files that covert fine).
GSpot gives me this:
Files with no error:
AUDIO_BITRATE                  384
AUDIO_BITRATE_TYPE             CBR
AUDIO_CHANNEL_COUNT            6
AUDIO_CODEC                    0x2000 (Dolby AC3) AC3
AUDIO_CODEC_STATUS             Codec(s) are Installed
AUDIO_MPEG_STREAM_ID
AUDIO_MPEG_SUBSTREAM_ID
AUDIO_SAMPLE_RATE              48000
Files with error:
AUDIO_BITRATE                  192
AUDIO_CHANNEL_COUNT            2
I cannot see why XVID4PSP (latest version) or Nero AAC encoder is doing this.
usta posted 2009 Nov 04 08:08
Try installing AC3Filter.
TheViking posted 2009 Nov 05 01:41
False alarm.
I tried a fresh install within a virtual machine. Success.
I also installed AC3Filter on my regular box. Success.
Must be something broken with my original install...
Thanks for your help.
Login/Register to our forum to be able to post here.
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
