Forum Archive Home -> Advanced Video Conversion -> Error message with XviD4PSP - encoding .TS to X264 MKV
| Error message with XviD4PSP - encoding .TS to X264 MKV |
| Phat J posted 2008 Sep 09 03:25 |
| Hey,
I would like to convert my 1080i TS file to a 720p X264 MKV using XviD4PSP, and I keep getting the error: "can't open stats file" I have no idea why this is happening. I have encoded a couple test clips I extracted from the same video file and they encode fine, but when I attempt to encode the whole file I always get this error. I am encoding it with 2 passes, 6500kb/s x264, audio set to copy, resize to 1280x720, progressive, and the color correction default "MPEG2fix." These are the exact settings I encoded the test clips with. Computer specs: Intel P4 3.2GHZ, WinXP MCE, 1GB Ram, nVidia 7600 GS Any ideas?? |
| Baldrick posted 2008 Sep 09 05:24 |
| "can't open stats file" is usally a problem when converting the second pass.
Does it stop when starting the second pass or directly when you convert? Are you converting the test clips using 2-pass also? |
| Phat J posted 2008 Sep 09 22:51 |
| Yes I forgot to mention, the error comes up right when the second pass starts, the first pass encodes fine.
The test clips are encoded with 2-pass as well. For one test clip, I frameserved the TS into VitualDub and extracted a clip as encoded in HUFFYUV format and opened that in XviD4PSP. I also tried a test clip I extracted a clip using MPG2CUT2, keeping the TS format. Both clips encoded fine with 2 passes ... I don't get it. |
Login/Register to our forum to be able to post here.
