Forum archive - Encoding for Multiple Devices
Forum Archive Home -> DVD Ripping -> Encoding for Multiple Devices
Scarpad posted 2009 Oct 01 12:38
I'm trying to get a File that is playable on my Ipod Touch, Zune and Somy PSP.
Both the Ipod and the Zune are fairly compatible and can play their files. he Hitch is the PSP
I have to keep the file at either 480x Under 272, or 720x480 for the PSP, plus there arre other restrictions as well
Anyone have any advice for getting a encode that will work on all three devices?
usta posted 2009 Oct 01 13:28
Option 1) Use MPEG4 SP (Divx) with 480x272 resolution.
Option 2) Restrict H264 profile (for example, no CABAC).
Scarpad posted 2009 Oct 01 19:15
PSP cannot Play Divx at any resolution
usta posted 2009 Oct 02 13:43
Scarpad :
Sure it can.
Divx is just the video codec used to encode a video that satisfies MPEG4 SP and packaged in MP4 container.
What converter are you using?
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
