Forum archive - Encoder for commercial use
http://www.supermediastore.com/
Forum Archive Home -> Mac -> Encoder for commercial use
Morten_Hjort posted 2009 Oct 15 07:06
I need a converter (MacOS 10.5+) that can convert videos to the attached specs...
What can you recommend? I know that Episode 5 might be the best but its also a littlebit expensive (999$). Is it worth every penny?
rumplestiltskin posted 2009 Oct 15 09:04
As you want WMV, you should check out the software at www.flip4mac.com
terryj posted 2009 Oct 15 12:35
Yup, Flip4Mac's WMV Studio Pro is the way to go.
Morten_Hjort posted 2009 Oct 16 02:27
But can WMV Studio Pro also make the aacPlus v2 version?
rumplestiltskin posted 2009 Oct 16 09:50
You may have painted yourself into a corner. You may have to encode your audio and video separately and then glom them together in some third-party resource.
Morten_Hjort posted 2009 Oct 17 12:14
rumplestiltskin :
Ahh I dont want to do that... So the only app that can make theses 2 filetypes are Episode 5?
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
