Forum archive - enc_aacplus.dll error while using AutoMKV
http://www.supermediastore.com/
Forum Archive Home -> DVD Ripping -> enc_aacplus.dll error while using AutoMKV
nx01rules posted 2009 Oct 14 11:21
Hey, so i'm trying to convert a DVD to an MKV file, I want to use AAC audio, and the x264 codec for the video in an MKV container - thing is, i'm trying to use AutoMKV, and each time I try and set up a file to be processed and start it, it stops when it gets to the audio converting stage:
* NOTE! enc_aacplus.dll must be into executable directory
* get it from Winamp 5.2 plugins directory
* tested on Winamp 5.2 Release Feb 23 2006 Full (Not Pro) version)
I'm using the standard build/release of AutoMKV (0.98.4), and it gives me this error. I also changed the enc_aacplus.dll file to a slightly different one which I found in winamp 5.2 (which it says to do above, in the error) - that didnt fix the error. Anyone know how to fix this annoying bug?
Cheers
Soopafresh posted 2009 Oct 14 13:31
Use the AAC encoder from Nero. It's better quality and AutoMKV will use it.
http://www.nero.com/eng/downloads-nerodigital-nero-aac-codec.php#
nx01rules posted 2009 Oct 15 04:17
OK cheers, i'll give it a shot.. But on the side, is there any way to get the normal one working? Just curious as to what the issue is here..
buzzqw posted 2009 Oct 15 04:24
automkv works with enc_aacplus bundled with automkv
also, automkv is a ended project
please use HDConverttoX
thanks
BHH
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
