Forum archive - Emachines EL1300G-01w DVD Burner
http://www.supermediastore.com/
Forum Archive Home -> DVD & Blu-ray Writers -> Emachines EL1300G-01w DVD Burner
Max Renn, Channel 83 posted 2009 Jun 27 03:51
Has anyone used the Emachines EL1300G-01w computer to burn DVD's? I can't find out what brand the burner in it is. I tried to backup a movie and it was breaking up/pixelating. I've not had that problem before with my 7 year old Compaq Presario with a LiteOn burner. I tried burning it in Nero9 at 8X speed, burn at once.
Anyone else had issues with this burner?
Thanks in advance.
Krispy Kritter posted 2009 Jul 29 10:38
My first thought would be a media issue. Either because the firmware is out of date, it doesn't properly support the media being used, or because you are simply using a low grade media.
Some things to try: 1) a quality media such as Verbatim or Taio Yuden 2) a better burning app - try ImgBurn, it performs better and it's free 3) try a slower burn speed (this can sometimes overcome burner/firmware/media issues.
As for your burner, try removing the drive and checking the drive label. You could also try a software app such as SIW ( http://www.gtopala.com/ ).
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
