Forum archive - Easiest way to convert HD-DVD to Blu-ray?
http://www.supermediastore.com/
Forum Archive Home -> Blu-ray Ripping -> Easiest way to convert HD-DVD to Blu-ray?
DGenerateKane posted 2009 Sep 08 18:54
Is there an easy guide out there? The only guide I've found requires several programs and doesn't say what you are supposed to do with said programs.
MOVIEGEEK posted 2009 Sep 08 19:51
http://forum.doom9.org/showthread.php?t=137151
Scroll down to HD-DVD.
DGenerateKane posted 2009 Sep 08 20:21
What if I want to keep everything? Do I need to demux and then mux every file?
wulf109 posted 2009 Sep 08 20:27
I've converted many of my HD-DVD's to blueray with Ripbot. Movie only,but Ripbot will join the evo files,usually two and convert to blueray.
minerva.thegift posted 2009 Sep 27 17:04
I have found that RipBot264 with mkvMerge GUI (part of the mkvToolnix) (and BDSup2Sub if you want subtitles) works great and is generally fairly easy (at least as easy as converting a standard DVD.) I've written a guide, and you can find it here (bit of shameless self-promotion :D)
If you start trying RipBot and have questions, feel free to PM me or drop me a line in my guide's thread. Good luck!
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
