Forum Archive Home -> DVD to DVDR -> DVDR-3380 Firmware upgrade
| DVDR-3380 Firmware upgrade |
| Spideray posted 2008 Feb 23 09:01 |
| DVDR-3380 Latest Firmware upgrade Info
------------------------------------------------------ v3.12 (25th Apr 2006) - Original Shipped Version v3.27 (23rd Feb 2007) - Fixes DivX6 issues + Freeze issues on disc update + trick mode T/C menu Make sure the recorder is empty !!! You will need to press <0><0><0><9><OK> to find which version www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG& ... k_Software Download the four files then burn the files to a CD-R and follow the steps when you place it in the recorder When you have finished the tray will be out don't panic just restart and all will be well. N.B.> DO NOT POWER DOWN DURING THE UPDATE !!!! Spideray |
| zolldam posted 2008 Sep 21 22:27 |
| Here is the link to firmware update for DVDR 3380/55 LATAM (Lantin America model)
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=PE&s ... k_Software |
Login/Register to our forum to be able to post here.
