VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Software Playing -> DVDdecrypter region code not set. Help
X_Splinter posted 2008 Sep 09 16:39
I was about to rip another dvd then...
As far as i know we should never change the region code of our dvdplayer, cause we have a limit to o that.
What should i do?????
nic2k4 posted 2008 Sep 09 16:44
If you're not sure, don't set it and just click ok on that last panel. That's what I do and so far no problem. Just noticed you still have 5 changes available, that means you've never set the region on that drive. It should still be able to decrypt, but you won't be able to play any movies with it until you set it.
X_Splinter posted 2008 Sep 09 17:08
It did decrypted the DVD and its plays it cause the DVD is "All Regions" i wonder why DVDDecrypter asked for that.
Probably it cant play dvds with region lock, whatever i only put dvds on my laptop to decrypt them so no big deal.
Thanks nic2k4 for the tips :wink:
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
