Forum Archive Home -> DVD to DVDR -> DVD9 Iso to DVD5 question
| DVD9 Iso to DVD5 question |
| winman42 posted 2008 Sep 13 10:41 |
| I have DVD9 iso file, and want to convert it to DVD5 size. Is there a way to convert this without burning to
DVD9, then ripping to TS folder, then compressing/converting? thanks, Win |
| minidv2dvd posted 2008 Sep 13 10:58 |
| several ways. dvdshrink will open and use iso files. winrar can extract the folders and isobuster can also. |
| winman42 posted 2008 Sep 13 11:30 |
| Thanks very much! Really appreciate the response, i'll try Winrar, and possibly dvdshrink.
thanks again. Win |
| louv68 posted 2008 Sep 13 13:07 |
| In addition to DVD Shrink, another free program that can extract an ISO to files is 7zip |
| redwudz posted 2008 Sep 13 14:12 |
| Thanks for that about 7-Zip, louv68. I use it all the time and I hadn't noticed it could extract ISO files. Guess I should RTFM more often. :lol:
I also would suggest Shrink for a quick and easy backup to DVD-5. If you want more quality, DVD Rebuilder is also a option. I don't know if it can open ISOs directly, though, and it will take a fair amount longer. But it's a good choice for longer videos that may lose too much quality with Shrink. |
Login/Register to our forum to be able to post here.
