Forum archive - DVD/VCR RECORDER WITH USB PORT seeking
http://www.supermediastore.com/
Forum Archive Home -> DVD Recorders -> DVD/VCR RECORDER WITH USB PORT seeking
neorican posted 2009 Oct 11 19:06
I am looking for a DVD/VCR RECORDER WITH A USB PORT that will play my videos via Flash Drive through my HD TV -- I am interested in Recommendations -- It is hard to tell if this feature is available by info on the net or even by asking a sales rep-
I did manage to find out that the following DVD VCR RECORDER combo units have this feature: SONY rdrvx560 ($170) and the LG rc 897t ( $220 )
Are there any other concerns about the above units that I should consider? Any Net reviews ?
Does anyone know of any others or what is your opinion of the above--
Thanks,,,,Ralph
johns0 posted 2009 Oct 12 02:35
Dont buy combo units like that,best to have a separate dvdrecorder and vcr in case you have to use a tbc between the vcr and dvdrecorder for copy guarded tapes you own,cant copy those types of tapes with a combo unit plus they are built cheap.
neorican posted 2009 Oct 12 10:53
Hi Johns0,
Thanks you for your quick reply--
My purpose for this type of unit is mainly to copy DVR ( NON-COPYRIGHT) TV programs that I wish to save and to make singing or speaking recordings-- The VCR part for converting ( non- copyright ) tapes to DVD is essentially just an extra since the price differential is not much --
I am interested in your comment that combo units are made CHEAP-- Is it the VCR part that is made cheap or the whole thing ?
Are you saying that DVD RECORDERS are made better ? If so , why and do you know of any that you can recommend?
Still looking for the combo unit info as as above.
I sincerely appreciate your info--
Thanks,,,,,Ralph
From johns0
_________________
LJB posted 2009 Oct 12 11:12
Have you researched the Western Digital media player (Model: WDAVN00BN) for your flash drive files?
Prices should be no more than $100.00.
neorican posted 2009 Oct 12 12:24
Hello LJB,
Thanks for your help, but I would still need the DVD VCR RECORDER COMBO , for everything else so it would not be worth it-- regular 4gb or 8gb flash drives to plug into a USB port are basically all I need --
Thanks,,,,Ralph
FROM LJB
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
