Forum Archive Home -> Mac -> DVD to PS3
| DVD to PS3 |
| Pliny posted 2008 Aug 19 19:32 |
| I have some 4:3 TV shows on my DVDs that I want to convert and watch from my PS3 HDD.
What the are highest bitrate videos I can make with Handbrake that will be compatible with the PS3? I'd like to have the video as close to the VOB quality as possible and AC3 sound. Anyone have the exact settings they use? If I choose the PS3 preset, then up the bitrate to say 5000 kbps and change the audio to AC3, will that work? Or if anyone can suggest another OS X/Windows program that they use for this... |
| Baldrick posted 2008 Aug 20 04:34 |
| If you are converting to mpeg-4 xvid or h264 is max 2000kbps well enough or use single pass Constant Quality / Target Quantizer mode(if possible in handbrake). |
| lawnman posted 2008 Aug 20 07:32 |
| Check out VisualHub. |
Login/Register to our forum to be able to post here.
