Forum archive - DVD to MP4 Audio Sync
http://www.supermediastore.com/
Forum Archive Home -> DVD Ripping -> DVD to MP4 Audio Sync
ee98vvt posted 2009 Oct 05 05:25
I am trying to rip an old (~60's) DVD as per usual to an MP4. I have got an issue with audio sync that nothing seems to cure it :(
I have spent an extensive amount of time evaluating different software for DVD ripping and video conversion. These include but are not limited to the following:
Handbrake
TMPGEnc
Any Video Converter
Nero Recode
MeGUI
After hundreds of trial and error experiments, I came to the conclusion that Nero Recode 3 does best suit my needs (Please feel free to suggest different tools but let's not convert this to "Best Video Converter" thread). The various tests I have carried out prove that Nero Recode 3 gives me a superb quality with minimum user effort. The latter is very important to me since I encode (and will be) several movies a day from a vast collection.
My methodology is as follows:
1. Rip DVD with DVDFab onto my hard disk in DVD native format (i.e. IFO and VOB files)
2. Convert the DVD from my hard disk to an MP4 (x264/H264 2Mbps CBR video and AAC Stereo 128kbps audio)
This usually works great! However, I've had loads of trouble with this old collection of movies. Around 40% of the final MP4 files are out of sync (audio vs video). I have tried all other tools mentioned above with no luck in fixing this! Any Video Converter has got a brilliant feature, which lets you choose a custom Audio sync factor using a slider that slides from value 0 to 60. Unfortunately, this fails miserably too :(
Can anyone please help? Any constructive feedback on my methodology would be appreciated too.
Baldrick posted 2009 Oct 05 06:09
I assume you have tried played those dvds to see that they are in sync before converting.
Be sure to opening the video_ts folder or ifo in the converters. Don't open/load VOB files.
Maybe try another ripper like dvddecrypter(works fine on older dvds) or anydvd and see if it make any difference.
ee98vvt posted 2009 Oct 05 14:04
That's a very good point :oops:
Being an engineer, my mind always complicates things..!! 40% of the original DVDs are actually out of sync!! I guess this is bad mastering and cannot be rectified :(
It's always a good idea to compare the result with the original source :oops:
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
