Forum Archive Home -> SVCD2DVD & VOB2MPG -> DVD to AVI using VOB2MPEG
DVD to AVI using VOB2MPEG | ||
| GT Music posted 2007 Jan 24 19:37 | ||
| I installed VOB2MPEG some time ago and was able to convert VOBs without any problems but just recently I can no longer use this APP. No matter if the VOB is on a disk or on the hard drive I get (Finished Processing 0 VOBSETS Duration 00:00:03) I have un-installed, updated and re-installed version 2.3 also I have installed Net.Framework 2.2 as I believe this is needed. It has been some time sense I've used this APP. and I can't imagine that I've completely lost my mind in usnig it properly. Maybe I have!!! can those who use this program help me out ?? My objective here is to re-edit video that has been recorded on a DVD Desktop recorder. IE our church play! ETC.! Thanks in advance
GT | ||
| redwudz posted 2007 Jan 24 22:13 | ||
| Your version of the program may not be completely compatible with Net 2.2. I'll move this post to the SVCD2DVD General Forum and ChrissyBoy may be able to give you better advice. :) | ||
| GT Music posted 2007 Jan 26 16:31 | ||
| This will be my second SOS HELP! I've had 85 hits on this request with no reply, Chrissy Boy can you help?. Can anyone help? I sure would appreciate it.
I installed VOB2MPEG some time ago and was able to convert VOBs without any problems but just recently I can no longer use this APP. No matter if the VOB is on a disk or on the hard drive I get (Finished Processing 0 VOBSETS Duration 00:00:03) I have un-installed, updated and re-installed version 2.3 also I have also uninstalled .Net Framework 2.0 and re-installed it. It's been about 5 months sense I've used this APP. and I can't imagine that I've completely lost my mind in usnig it properly. Maybe I have!!! can those who use this program help me out ?? My objective here is to re-edit video with Vegas 6 that has been recorded on a DVD Desktop recorder. IE our church play! ETC.! Thanks in advance GT | ||
| MaxxFordham posted 2007 Jul 23 22:21 | ||
Um, actually, if a file is on the hard drive, it IS already on a disk (hard DISK drive). So maybe the question would be if the file is on the hard disk or on a removable disk or disC (and then to that you could say here that no matter what kind of disk or disc the VOB is on, you have that problem). | ||
| dweeeb posted 2009 Oct 18 07:37 | ||
| In case anybody is still having this problem (I was...), here is a possible solution: in my case, the disk where I was trying to save the output was full...
Seems that VOB2MPEG reacts to that by just stopping the conversion when the disk is full with the message "finished processing". |
Login/Register to our forum to be able to post here.
