Forum archive - DVD Regions?
Tmpg-inc
Forum Archive Home -> DVD & Blu-ray Players -> DVD Regions?
DVD Regions?
contra22 posted 2005 Jan 11 22:22
Hi all, just wondering whether you can watch Region 2 DVDs in Region 4 (Australia) without needing a multi-region player as I've heard from a couple of people that it's possible?
daamon posted 2005 Jan 11 22:27
You might be able to hack the player into a multi-region... See "DVD Hacks" link to the left for the player in question.
If it's on the PC you're talking about, you can get software that bypasses the region setting and so is effectively multi-region. DVD Region Free is one example...
Forum Troll posted 2005 Jan 11 23:59
One other way is to rip it to your computer with DVD Decrypter, this makes it region free, then burn it to a recordable DVD.
griffmaster posted 2005 Jan 13 19:02
I live in UK, and most movies I buy say on them Region 2+4, so i think that most will play as ok. I have ordered DVDs from the web and I have got a R4 version (as they are dual coded) and they play perfect on a region 2 only player. I think since UK is R2 PAL and Aus is R4 PAL they are just the same.
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
