VideoHelp.com forum archive
Tmpg-inc
Forum Archive Home -> Media -> DVD previously played now not recogized on Oritron DVD4119
pnash posted 2008 Oct 01 08:18
A commerecial quality DVD (produced by Deutches Grammaphone) having a Region Code of 0 was played successfully twice on this unit. Thereafter attempts to play it fail - after loading the screen remains blank with no error messages. This same unit plays other DVD's normally with no problem.
The affected DVD plays with no problems on multiple other units and on several PC's.
I have hacked the unit's region code, verified that it is a Region 1 unit (region 0 DVD's play on All Regions). I have tried changing the unit to Region 0 but this makes no difference.
It is a mystery. I have no idea what the problem could be.
Any ideas?
Mystified in the Bermuda Triangle
tinker posted 2008 Oct 01 08:53
Did you look at DVD data side, does it look clean and consistent?
It could also be that your player's lens is little dusty, try to clean it.
Since it played before and play on other players, it could be combination of dirt and not so perfect DVD.
pnash posted 2008 Oct 01 10:10
Thanks, Tinker, I did look at the data side and cleaned it (although it did not need it). It is a brand new DVD only played fully twice with no trouble on the unit. The unit also plays other discs fine which seems to suggest the unit is functioning okay.
Still puzzled, but thanks, I appreciate the reply.
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
