Forum archive - dvd audio problems
http://www.supermediastore.com/
Forum Archive Home -> Authoring (DVD) -> dvd audio problems
dvd audio problems
jchmbs posted 2009 Oct 24 07:36
Hi Everyone,
I have an audio problem while burning .avi movie to a dvd with Adobe Encore (actually also with Nero).
The strange thing is that not all the audio is gone, some pieces are still there, but mostly there is no sound at all. Unfortunately I only got an exported avi file (All the audio layers are melted together) left to work with.
Another thing I don't get is that when I import my file into Premiere all the audio is still there. So the file seems good, but in fact something isn't right?! The dvd burning software (Encore and Nero) has skipped the same audio parts. When I play the dvd on my computer it works (all the audio is there) but when I try to play it on several dvd-players (connected to the television) the same audio problem occurs. The audio problem only occurs with one file, i burned to .avi's on the dvd, the other one is fine.
I really hope you can help me out!
Thanks a lot!
Jochum
t0nee1 posted 2009 Oct 24 08:33
I don't use Adobe Encore or Ner0, so can't comment on them..My guess is, the apps used are not creating a proper DVD..What are the specs of the audio, MP3, perhaps?...If so, use ac3..Better yet, try something like DVDflick or ConvertxtoDVD which will create a proper DVD for you...
Perhaps someone that uses the proggies you've mentioned, will chime in..
Good luck!.
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
