Forum archive - DV encoded Sound Problems
http://www.supermediastore.com/
Forum Archive Home -> Camcorders (DV/HDV/AVCHD) -> DV encoded Sound Problems
zack28 posted 2007 Sep 21 16:13
Hi
My Raw DV (vhs to Pc) file (60gb) has pefect sound, but when i encode my Video with Nero Encode (DVD9 VideoTS) folder, the first part of the movie has missing sound, on the first 2 hrs of video (in some areas in appears for 2 secs than goes away again).
Can someone help
Baldrick posted 2007 Sep 21 16:48
Convert with something better. Tmpgenc dvd author 3!
zack28 posted 2007 Sep 21 18:20
I'll try that tommrow.
Just one important thing.
Nero gave me a option to create chapters (layer break) (a Must For DVD9) as my DV movie runs continuesly start to finish (i want the DVD to do the same), is there a such a option in Tmpgenc. If So where abouts are the options when converting DV to VideoTS.
I'm burning to a DVD9 Verbatim +R (DVD9) does Tmpgenc support DVD9 media
Once the VideoTS is created i load the VideoTS into Build Mode in IMGBURN
Press the Calculater (which then gives me the Layer break options to choose) then create ISO
Login/Register to our forum to be able to post here.
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
