Forum Archive Home -> Audio -> DTS 1536 kpbs not clear with VLC
DTS 1536 kpbs not clear with VLC | ||||||
| foaley77 posted 2007 Apr 16 08:06 | ||||||
| I'm trying to play a x264 movie that has a 1536 kpbs DTS soundtrack through my 5.1 DTS Yamaha Amp, My amp picks up the dts track but it's not very clear is there some setting in VLC to fix this up. I have tried some other DTS x264 movies and they work fine but they are around 754 kpbs
cheers | ||||||
| Soopafresh posted 2007 Apr 16 09:43 | ||||||
| 1536 is 48000hz WAV resolution. Wow... | ||||||
| foaley77 posted 2007 Apr 19 17:46 | ||||||
| Does anyone know? | ||||||
| edDV posted 2007 Apr 19 17:59 | ||||||
We know that 1536Kb/s isn't DTS. Start over. It might help to read this first. http://en.wikipedia.org/wiki/Digital_Theater_System | ||||||
| Soopafresh posted 2007 Apr 19 18:05 | ||||||
| From the VLC support site (might be applicable, might not)
The major change between 0.8.1 (actually 0.8.2) and 0.8.5 (actually 0.8.4) concerning DTS was regarding the rebuild of the DirectX module. This change forced Microsoft's recommendation of driver updates to be a reality when using VLC. Yet the best timing for ac3 or DTS is using the older method of addressing the audio card. Preferences, Audio, Output modules --- from the pull down select "Win32 waveOut extension output" than press Save and close the player. For a few cards (realtec ac97 and audigy) the drivers are still at issue and there are replacement drivers that work. As for any changes that would effect 0.8.6 from 0.8.5, I am aware of none and can't confirm it here on a working machine. I am aware of the issues with many programs and DTS and you may want to investigate a program called DTSParser.exe as it allows DTS wave files to be played in MPC or any Direct Show player that has Gabest's DTS parser (dtsac3source.ax) installed. Of coarse there will also need to be an appropriate decoder like ac3filter if you don't use MPC. VLC will also play these corrected files. | ||||||
| foaley77 posted 2007 Apr 19 18:36 | ||||||
| ok cheers I had already has this Win32 waveOut extension output setting on as the 5.1 tracks where shuttering but the dts track still does | ||||||
| manono posted 2007 Apr 19 18:58 | ||||||
Ah, but it is. It's full bitrate DTS. Even your link supports that. The 768 ones are half bitrate and much more common. I own a DVD with full bitrate DTS on it:
http://www.dvdtherapy.com/review_info.php?id=351 | ||||||
| edDV posted 2007 Apr 20 02:17 | ||||||
I have never seen a DVD with more than 768Kb/s DTS and when I look at Amazon and Netflix descriptions of this title, they don't show a DTS track at all. http://www.amazon.com/House-Flying-Daggers-Takeshi-Kaneshiro/dp/B0007Q6VXC Is this a special release? And if so how is it identified and where can it be purchased? Do you know of other DVD titles with 1500Kb/s DTS tracks? I want to own at least one. | ||||||
| foaley77 posted 2007 Apr 20 03:14 | ||||||
| Mad Max has a dts 1536Kb/s track
http://www.michaeldvd.com.au/Reviews/Reviews.asp?ReviewID=1830 | ||||||
| manono posted 2007 Apr 20 03:24 | ||||||
| Hi-
Mine's an R3 Hong Kong release. It's no longer in print, although there's a 2-disc version available. Although I can't conclusively prove it's full bitrate DTS, all the signs point to it:
http://www.dvdtimes.co.uk/content.php?contentid=57221 Available here (but you might be able to do better somewhere else): http://www.pokerindustries.com/poker.store?page=item&sku=HOUSEDAG2D-DVD And the famous "Echo Game" scene is a wonder to listen to. As for others, the R3 Korean SE version of Avalon has full bitrate DTS:
http://www.dvdtherapy.com/review_info.php?id=114 And there are some lists around: http://www.theimportforums.com/viewtopic.php?t=4 http://www.dtvforum.info/lofiversion/index.php/t21660.html http://www.avsforum.com/avs-vb/showthread.php?p=10124722&&#post10124722 http://www.spannerworks.net/reference/10_6a.asp | ||||||
| edDV posted 2007 Apr 20 03:52 | ||||||
| Thanks much. I want to experience full DTS.
Time to break out the receiver manual to verify it plays 1500Kb/s DTS. | ||||||
| Soopafresh posted 2007 Apr 20 13:17 | ||||||
| Just reminded of some 1536 samples that I couldn't play on my system:
http://www.sr.se/cgi-bin/mall/index.asp?ProgramID=2446 Most of these files have a .WAV extension. Change to .dts for next step: Had to run the files through Dtsparser.exe to get them to work. Perhaps the magic bullet.... http://hypercubemx.free.fr/html/download.php?download_id=4 ![]() | ||||||
| foaley77 posted 2007 Apr 21 04:43 | ||||||
| How do i get the dts track in the Dtsparser.exe program, I'm working with a x264 movie clip
do I have to convert to wav or somethink? | ||||||
| Soopafresh posted 2007 Apr 21 05:18 | ||||||
| No, you need to demux it. Download Yamb v1.6 and it should be pretty straightforward.
http://yamb.unite-video.com/download.html ![]() | ||||||
| BJ_M posted 2007 Apr 21 07:18 | ||||||
if it plays half dts, it will play full ..... also - listen to some 96/24 dts disks and DTS audio 20bit cd's | ||||||
| foaley77 posted 2007 Apr 21 08:15 | ||||||
this program does not recognize my x264 movies, should it be? | ||||||
| edDV posted 2007 Apr 21 13:45 | ||||||
My receiver does accept digital 96Kb/s 24bit but only as 2 channel stereo. | ||||||
| edDV posted 2007 Apr 21 14:05 | ||||||
| [quote="Soopafresh"]No, you need to demux it. Download Yamb v1.6 and it should be pretty straightforward.
http://yamb.unite-video.com/download.html[\quote] So if he can demux the DTS track which software players can decode and play DTS ? | ||||||
| Soopafresh posted 2007 Apr 21 15:01 | ||||||
| ed - Hee hee. No, I found some dts samples which my system wouldn't play correctly (see link below). Running the "problematic" (at least to my PC and decoder) file through Dtsparser.exe resulted in a file without the audible artifacts of the original. What I'm hoping is that the same procedure can help foaley77 ---> demux dts from file and fix, remux a/v into new file.
In other words, I don't think the problem is full vs half, but rather the dts file itself is borked. Try the multichannel check file (rename .wav to .dts) : http://www.sr.se/laddahem/MultiKanal/Dts/SURROUNDTEST_011212.zip foaley77 - what is the extension of your file ? Is it .MP4 ? MKV ? .TS ? | ||||||
| BJ_M posted 2007 Apr 21 17:44 | ||||||
| the above is encoded for dts audio cd -- it is a different encoding process than for a dvd = also a different sample rate | ||||||
| foaley77 posted 2007 Apr 21 19:07 | ||||||
MKV | ||||||
| Soopafresh posted 2007 Apr 21 19:56 | ||||||
| MKV Demux
http://sourceforge.net/projects/mkv-demux-all BJ_M - Yeah, I know, but what are the other options... It won't hurt to test it out. | ||||||
| foaley77 posted 2007 Apr 21 21:14 | ||||||
| I demux the MKV then I used Yamb and tried to extract the audio and it brings this up
[11:39:03] : YAMB 1.6.0 started ! [11:39:03] : OS type detection... [11:39:03] : Windows XP Professional [11:39:03] : Checking MP4Box location...MP4Box found. [11:39:03] : Checking MediaInfo.dll...0.7.1.2 found. [11:39:30] : Extracting started... [11:39:30] : Exporting & Converting stream... [11:39:30] : Error: Requested URL is not valid or cannot be found [11:39:30] : Error: Requested URL is not [11:39:30] : Error: Requested URL is not valid or cannot be found [11:39:30] : Exporting failed. [11:41:24] : Extracting started... [11:41:24] : Exporting & Converting stream... [11:41:24] : Error: Requested URL is not valid or cannot be found [11:41:24] : Error: Requested URL is not [11:41:24] : Error: Requested URL is not valid or cannot be found [11:42:21] : Muxing failed. [11:42:25] : Extracting started... [11:42:25] : Exporting & Converting stream... [11:42:25] : Error: Requested URL is not valid or cannot be found [11:42:25] : Error: Requested URL is not [11:42:25] : Error: Requested URL is not valid or cannot be found [11:42:25] : Exporting failed. [11:42:36] : Extracting started... [11:42:36] : Exporting & Converting stream... [11:42:36] : Error: Requested URL is not valid or cannot be found [11:42:36] : Error: Requested URL is not [11:42:36] : Error: Requested URL is not valid or cannot be found [11:42:36] : Exporting failed. | ||||||
| Soopafresh posted 2007 Apr 21 21:49 | ||||||
| Yamb not required for the demux part. Once you run MKVdemux, you should be left with at least a dts file and an h264 file. Then, run the dts file through DTSparser (see link below)
| foaley77 posted 2007 Apr 25 22:08 | ||||||
Ok I ran mkv demux and it gave me an other file then I opened DTS Parser , The problem now is the file will not show up under the DTS Parser when i try to add the file.
| BJ_M posted 2007 Apr 26 00:47 | ||||||
| try changing the extension | ||||||
| foaley77 posted 2007 Apr 26 01:04 | ||||||
| How do i do that? | ||||||
| Soopafresh posted 2007 Apr 26 09:16 | ||||||
In windows explorer
| foaley77 posted 2007 May 03 19:15 | ||||||
| Still won't work using file.cpt | ||||||
| Soopafresh posted 2007 May 03 19:53 | ||||||
| Right click on the file below and download. Place in same folder as your file.cpt file. Double click it to run. It should create a file.dts file. Then run THAT through the DTS parser.
cpt2dts.cmd | ||||||
| Jon.G posted 2009 Jan 10 18:49 | ||||||
| I had dtsparser, and my stupid computer decided to delete a folder other then the one I told it to and overwrite the data immediately. I keep searching high and low for dtsparser, but everyone keeps linking to invalid places. Where the hell is this? Why do you keep redirecting to bad links? Stop doing that, and get me the damn file. |
Login/Register to our forum to be able to post here.
