Forum Archive Home -> Audio -> Dolby AC3 5 channels - voices are not playing
Dolby AC3 5 channels - voices are not playing |
| dexter30 posted 2009 Oct 28 17:45 |
Hi. I have this video file. When playing with VLC there are no voices, only background sounds. MPC will play the voices but the whole audio is way too low. what should I do? Thanks in advance.
| Baldrick posted 2009 Oct 28 17:58 |
| In VLC try change Audio->Audio Device->Stereo.
Or if you want to use MPC or WMP then just install AC3 Filter and boost the audio volume in it. |
Login/Register to our forum to be able to post here.
