Forum archive - Does Imovie Work Better with H264 ?
http://www.supermediastore.com/
Forum Archive Home -> Mac -> Does Imovie Work Better with H264 ?
smartduck posted 2009 Oct 30 06:40
Hello y'all experts
I am currently recording clips with a Sony Mini DVD (MPG2) camera and editing the clips in Imovie 09 just to put a short intro and some subtitles. Unfortunately, the export quality of the clip is awful. The original MPG2 is quite good looking, albeit interlaced.
My questions:
1) Is there any alternative to Imovie that would let me edit the clip in the original MPG2 format, and insert the intro, etc, without a conversion? I know MPG2 is not a good format to edit, but maybe there is some solution.
2) Would I benefit at all if I start using a camera that records in H264 ? Or Imovie would convert the clip to AIC and wreck the quality anyways ?
Thanks a lot.
Herve posted 2009 Oct 30 08:08
hello
smartduck :
My questions:
no you find some editiong abilities in MpegStreamClip (or Toast)
they are very limited (trim, cut, paste) and not very user-friendly nor accurate … but they exist ;)
same behavior: mpeg2 or h264 are broadcasting formats
AIC or DV are editing formats
You need to convert every " broadcasting formats" to edit it safely (finally, it's only a temporary -huge- file for your edit)
wrong, iMovie '08 or '09 doesn't damage your file if you don't use its presets.
Every iMovie presets produce bad quality with interlaced files :(, so export to AIC from iMovie: huge resulting size, but you can process it later to a bradcasting format with a real soft (MPegStreamclip, etc)
iMovie does not damage everytime, you just need to mislead it defaut behavior :(
bye
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
