Forum Archive Home -> Media -> Disc C2 Errors
| Disc C2 Errors |
| kidcash posted 2008 Jul 05 08:52 |
| Hello,
I have a data CD disc that seems to work ok and I seem to be able to access my data fine. I used Nero CD-DVD Speed to check for errors and it came up with :
I see that I have no C1 Errors and a lot of C2 Errors, but I am still able to access my data, but if the cd works fine how come the program shows that there is errors? Also every time I check the error count is different |
| redwudz posted 2008 Jul 05 11:56 |
| I'd first try a different brand disc. Errors are always there, but small ones shouldn't cause any problems. If a different brand disc shows less errors, then change brands.
What program did you use to burn the disc? Likely makes no difference with a CD data disc, but you could try ImgBurn. I haven't tried Nero CD-DVD Speed on a CD disc, so I don't know if that error count is excessive or normal. But others here may have some ideas. :) |
Login/Register to our forum to be able to post here.
