Forum archive - Creating an AVCHD DVD disc on a mac
http://www.supermediastore.com/
Forum Archive Home -> Mac -> Creating an AVCHD DVD disc on a mac
mattr posted 2008 Nov 16 00:22
Hi. I was wondering how an AVCHD DVD disc is created on a mac. I know how it's done on a windows computer, but I don't have access to a windows computer that is fast enough to transcode HD video. I can't seem to find any information on how to do this. Can anyone help me out?
AntnyMD posted 2008 Nov 18 13:20
Some recommend not using AVC for high definition discs on Mac. Longer encodes tend to have a/v sync issues. In Compressor, for example, it's Blu-ray setting uses high bitrate MPEG2 (which is a part of the standard). If you have it, you can also use the Episode encoder (it has settings that can be tweaked for AVC, MPEG2 and VC-1).
Vintage posted 2008 Nov 18 15:51
look for tsmuxer. It's used to turn ripped Blue Ray movies into avc hd disc to play on hardware like Playstation 3 but I'm sure some of the info can be helpful to you.
peckinpah posted 2009 Jan 13 08:01
I'm looking for something similar that would allow me to convert my hd mkv files to AVCHD. My sony Bu-Ray player will play back dvds that are encoded with these files. Any instructions? The usual mac apps (ffmpegX, VisualHub R.I.P., MPEG Streamclip) don't seem to be able to do the job. From what I've seen on the internet, it is possible to create these disks relatively easily on a PC. Arghh!
mattr posted 2009 Jan 15 03:13
I have worked out a way to do it. I have made five AVCHD discs so far. The How-To is still being drafted, and hopefully I will be able to release it soon.
peckinpah posted 2009 Jan 16 16:21
any hints?
mattr posted 2009 Jan 16 20:39
peckinpah :
any hints?
i haven't created any new applications. That is all i can say at age moment.
adcvideo posted 2009 Jan 16 21:39
I have used Toast 9 to create AVCHD DVD-R discs that have played successfully on my PS3. The encode times were very slow, however.
peckinpah posted 2009 Jan 19 09:55
I'm trying to avoid re-encoding the material. My understanding is that on a PC it's really easy to just convert the container without altering the actual image. It should also be a lot faster.
peckinpah posted 2009 Jan 22 15:47
if you could hint at what apps you're using, I might be able to figure it out myself... ;)
dizzie posted 2009 Oct 30 20:07
Any new info here for Mac users? Thought I should resurrect a thread from the dead for Halloween... ; )
ffooky posted 2009 Oct 31 05:59
I used tsMuxeR to create the two folders and Toast (with the HD-BD plugin) to burn. It worked well apart from the subs going AWOL. tsMuxeR is currently borked for OS 10.6 alas but there's no transcoding involved.
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
