Forum Archive Home -> Editing -> Corel VideoStudio 12
Corel VideoStudio 12 | ||
| netmask56 posted 2009 Oct 31 19:52 | ||
A friend has ask me to fix his install of Corel VideoStudio 12. He installed it on a new computer running Windows 7 Ultimate and has a HD widescreen monitor. Basically it all works until the final stage where he can't get past the preview screen - there is no Next button! I've loded a few small jpg's that illustrate the issue. I have tried all the usual like running the program in Vista and XP mode SP2 and Sp3. Even tried Windows 2000! But nothing seems to be able to fix it. A thought could it be the 16:9 monitor? Must get hold of a standard 4:3 monitor to try. Any help most grateful. The first picture is how it looks installed and the one below is how it should look
| MOVIEGEEK posted 2009 Oct 31 21:08 | ||
| Try changing the monitors resolution(eg 1024x768) or using ALT N:
http://forum.corel.com/EN/viewtopic.php?t=35603 | ||
| JustOneOfMany posted 2009 Oct 31 21:17 | ||
| I have the same problem.
The only thing that works so far to get me to next menu is pressing <Alt><N> You can then burn etc... | ||
| netmask56 posted 2009 Oct 31 21:48 | ||
Report back from my friend confirms Alt N works - thanks | ||
| MOVIEGEEK posted 2009 Nov 20 00:25 | ||
| There's a patch to fix it now, it's the one dated 2009/11/10:
http://www.origin.corel.com/servlet/Satellite/jp/jp/Content/1221854353274 |
Login/Register to our forum to be able to post here.
