VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> DVD to DVDR -> Copy dual layer dvd
Copy dual layer dvd
Gerald Sr. posted 2008 Oct 01 21:21
I'm confused, I would like to know how to copy dual layer dvd. First, do I need to install a dual layer burner in my computer or can I just use my dvd burner to copy a dual layer dvd using blank dual layer disc.
Baldrick posted 2008 Oct 02 02:21
You need a dual layer burner to burn dual layer media....Use Imgburn.
jman98 posted 2008 Oct 02 06:57
You've been here 3.5 years and you still don't know how to do this? Let me guess - you're one of those people who only posts when he has a question and never pays attention otherwise, right? Also, you are fairly lazy as you can find guides on how to do this.
The basic procedure is:
1) Rip the DVD using DVDFab HD Decrypter or AnyDVD. Older ripping tools don't get updated and may not work with all DVDs.
2) Use Verbatim DVD+R DL discs or you are asking for problems.
3) Burn with ImgBurn or you are asking for problems.
filmboss80 posted 2008 Oct 02 09:51
Adding to jman98's post:
4) Make sure you have a dual-layer DVD burner. (ImgBurn has a function that will tell you what your hardware is capable of burning.)
Gerald Sr. posted 2008 Oct 02 20:39
Listen Jman98, there is a reason we ask a certain question. We haven't reach your expertise as yet pal. Thanks very much for the insult. If you are ithe kind that insult a member whenever they ask a question, DON'T ANSWER THE DAMN THREAD. IDIOT.
Supreme2k posted 2008 Oct 03 01:47
You see, that is EXACTLY the type of attitude that prevents you from learning anything.
jman is 100% correct. Shame on you! You are a lazy s.o.b. That is one of the most basic of basic questions for this site. He was much more helpful than he should have been. Most would have directed you to the guides on the left.
Unless the Sr. means that you're 90 or so, then you're excused and also commended for even being able to get on the internet.
filmboss80 posted 2008 Oct 03 09:27
Okay, let's take a deep breath. Gerald Sr., if you can look past any perceived offenses, you will find that jman98 and Baldrick have provided the solution to your problem. Good luck to you.
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
