Forum archive - Converting PAL to NTSC error Attempted to read or write protected memory.
http://www.supermediastore.com/
Forum Archive Home -> SVCD2DVD & VOB2MPG -> Converting PAL to NTSC error Attempted to read or write protected memory.
VHSonDVD posted 2009 Oct 14 04:50
Hello folks. I am a new user of SVCD2DVD, primarily using it to convert PAL to NTSC to send to a friend in North America.
I have done a couple and been really pleased with the quality of the end result.
I am using 1clickDVD to shrink the source DVD to the required size and then ripping the result files to my hard drive.
I then use SVCD2DVD with the option QuickDVD (no menu or burn) and finally use 1click to burn the result to disc.
I have an 'episode' type DVD which is causing my problem. I get the error (see below error followed by log file) right at the end when SVCD2DVD is authoring titleset #1 at 50%.
I usually use 2 pass to get best quality but read a suggestion to try with just 1 pass - this produced the same error. SVCD2DVD is not installed in program files either.
1clickDVD is usually good with episode files and the source disc plays fine on my DVD players.
Any suggestions much appreciated. I am running Vista Basic SP1 on a 2GB intel. The log shows I was running low on disc space but I have run it earlier and got the same error when there was more disc space available. Having had a few crashes of this type I now need to clean up the crap as I had 27GB free when I started this morning!
Error message:
Version: SVCD2DVD 2.5
Build: 2.5.5030.0
Type: System.AccessViolationException
Source: SVCD2DVD
Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359ffc3()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac9ae()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Log:
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.5030.0
Executable: C:\svcdtodvd\SVCD2DVD.exe
Executable size: 2.58 MB
Executable size in bytes: 2711635
Executable CreationTime: 28/01/2009 15:57:36
Executable LastWriteTime: 08/10/2009 15:22:18
Executable LastAccessTime: 08/10/2009 15:22:18
************************* Operating System *************************
Operating System: Microsoft® Windows Vista™ Home Basic
Service Pack: Service Pack 1
Version : 6.0.6001
Windows Directory : C:\Windows
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 0.99 GB
Free Physical Memory: 425 MB
Total Virtual Memory: 2.24 GB
Free Virtual Memory: 1.27 GB
***************************** Computer *****************************
Computer Manufacturer Name: System manufacturer
Computer Model: System Product Name
System Type: X86-based PC
Computer Name: TEMP-PC
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: temp-PC\temp
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Celeron(R) CPU 440 @ 2.00GHz
Description: x64 Family 6 Model 22 Stepping 1
CPU Speed: 2GHz
CPU FSB: 200MHz
L2 Cache Size: 512 bytes
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: Intel(R) 82945G Express Chipset Family
Processor: Intel(R) 82945G Express Chipset Family
Mode: 1280 x 768 x 4294967296 colors
Video Ram: 224 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 17.0 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<?xml version="1.0" encoding="utf-8"?>
<SVCD2DVD DateTime="14/10/2009 08:41:25" Filename="C:\Users\temp\Documents\NTSC conversion files\if tomorrow comes disc 2 project.s2d">
<AssetSet>
<Asset ID="14ff2eca-bd24-4349-8e11-e352b4553a9c" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_01_0.VOB" />
<Asset ID="4ddf9553-6307-4cba-b423-98d9f4fa1de9" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_01_1.VOB" />
<Asset ID="d0b9b32a-478a-4332-8b1e-b23ad5597680" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_02_1.VOB" />
<Asset ID="b00a63eb-1503-4cbe-9485-0ad58ea9ed83" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_03_1.VOB" />
<Asset ID="c583dbe9-6ec8-4220-9fa4-75220ef4b75d" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_03_2.VOB" />
<Asset ID="604cb759-5ae1-4ad8-96a3-4d0ee45b5936" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_1.VOB" />
<Asset ID="3ae72a75-536d-4cb6-ae30-01d2f9965944" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_2.VOB" />
<Asset ID="ea05380c-0429-4092-8eaf-62bdcfafac66" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_3.VOB" />
</AssetSet>
<DVDStructure>
<TitleSet Name="VTS_01_0" PostCmd="" MenuButtonType="0">
<MenuButton X1="0" Y1="0" X2="195" Y2="58" FontFamily="Arial Unicode MS" FontSize="27.75" FontStyle="3">VTS_01_0</MenuButton>
<Title Name="VTS_01_0.VOB" AssetID="14ff2eca-bd24-4349-8e11-e352b4553a9c" MplexOffset="0" />
<Title Name="VTS_01_1.VOB" AssetID="4ddf9553-6307-4cba-b423-98d9f4fa1de9" MplexOffset="0" />
<Title Name="VTS_02_1.VOB" AssetID="d0b9b32a-478a-4332-8b1e-b23ad5597680" MplexOffset="0" />
<Title Name="VTS_03_1.VOB" AssetID="b00a63eb-1503-4cbe-9485-0ad58ea9ed83" MplexOffset="0" />
<Title Name="VTS_03_2.VOB" AssetID="c583dbe9-6ec8-4220-9fa4-75220ef4b75d" MplexOffset="0" />
<Title Name="VTS_04_1.VOB" AssetID="604cb759-5ae1-4ad8-96a3-4d0ee45b5936" MplexOffset="0" />
<Title Name="VTS_04_2.VOB" AssetID="3ae72a75-536d-4cb6-ae30-01d2f9965944" MplexOffset="0" />
<Title Name="VTS_04_3.VOB" AssetID="ea05380c-0429-4092-8eaf-62bdcfafac66" MplexOffset="0" />
</TitleSet>
<DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\svcdtodvd\default.jpg" AudioPath="" />
</DVDStructure>
<Settings>
<General InitialAssetFolder="C:\Users\temp\Documents\if tomorrow comes PAL" InitialDVDFolder="C:\Users\temp\Documents\NTSC conversion files" OutputFolderName="If Tomorrow Comes NTSC DVD" InitialProjectFolder="C:\Users\temp\Documents\NTSC conversion files" InitialMenuBackgroundFolder="C:\Users\temp\Documents\NTSC conversion files" DeleteS2DFiles="True" UseDVDShrink="False" />
<Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="C:\Users\temp\Pictures\if tomorrow comes.jpg" TVStandard="NTSC" FontFamily="Arial Unicode MS" FontSize="27.75" FontStyle="3" PlayAllText="Play All episodes" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
<Process AudioEncoding="ac3" Chapters="Every 30 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
<Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
<Burning BurningMethod="ImgBurn 2+" ImgBurnPath="C:\Program Files\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="True" DVDDDontBurn="False" />
</Settings>
</SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 2.56 MB
file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_01_0.VOB
FormatName=mpeg
Num_Frames=1964
DurationInSecs=79
Duration=00:01:18.5
VideoCodec=mpeg2video
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=274
AudioStreamCount=1
Audio1FFSTNum=2
Audio1StreamID=[0x80]
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=224
Audio1Channels=2
Processing VTS_01_0.VOB
Leaving source audio alone.
08:41:25: Converting PAL to NTSC (DVD Profile)
File Size: 25.1 MB
file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_01_1.VOB
FormatName=mpeg
Num_Frames=1084
DurationInSecs=44
Duration=00:00:43.3
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=4869
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
[VTS_01_0] 08:41:30: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_01_0] 08:41:30: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_01_0] 08:41:30: libavutil 49.12. 0 / 49.12. 0
[VTS_01_0] 08:41:30: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_01_0] 08:41:30: libavformat 52.23. 1 / 52.23. 1
[VTS_01_0] 08:41:30: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_01_0] 08:41:30: libswscale 0. 6. 1 / 0. 6. 1
[VTS_01_0] 08:41:30: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_01_0] 08:41:30: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_0.VOB':
[VTS_01_0] 08:41:30: Duration: 00:01:18.56, start: 0.280000, bitrate: 274 kb/s
[VTS_01_0] 08:41:30: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8000 kb/s, 25.00 tb(r)
[VTS_01_0] 08:41:30: Stream #0.1[0x20]: Subtitle: dvdsub
[VTS_01_0] 08:41:30: Stream #0.2[0x80]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_01_0] 08:41:30: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_0_S2D.mpg':
[VTS_01_0] 08:41:30: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_01_0] 08:41:30: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_01_0] 08:41:30: Stream mapping:
[VTS_01_0] 08:41:30: Stream #0.0 -> #0.0
[VTS_01_0] 08:41:30: Stream #0.2 -> #0.1
[VTS_01_0] 08:41:30: [mpeg2video @ 0x2a76b90]Using pulldown for PAL->NTSC.
[VTS_01_0] 08:41:30: Press [q] to stop encoding
[VTS_01_0] 08:41:30: video:0kB audio:2150kB global headers:0kB muxing overhead 1.773359%
Processing VTS_01_1.VOB
08:41:31: Converting PAL to NTSC (DVD Profile)
File Size: 2.13 MB
file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_02_1.VOB
FormatName=mpeg
Num_Frames=249
DurationInSecs=10
Duration=00:00:09.9
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=1799
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=224
Audio1Channels=2
[VTS_01_1] 08:41:31: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_01_1] 08:41:31: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_01_1] 08:41:31: libavutil 49.12. 0 / 49.12. 0
[VTS_01_1] 08:41:31: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_01_1] 08:41:31: libavformat 52.23. 1 / 52.23. 1
[VTS_01_1] 08:41:31: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_01_1] 08:41:31: libswscale 0. 6. 1 / 0. 6. 1
[VTS_01_1] 08:41:31: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_01_1] 08:41:31: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_1.VOB':
[VTS_01_1] 08:41:31: Duration: 00:00:43.39, start: 0.280000, bitrate: 4869 kb/s
[VTS_01_1] 08:41:31: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8000 kb/s, 25.00 tb(r)
[VTS_01_1] 08:41:31: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_01_1] 08:41:31: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_1_S2D.mpg':
[VTS_01_1] 08:41:31: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_01_1] 08:41:31: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_01_1] 08:41:31: Stream mapping:
[VTS_01_1] 08:41:31: Stream #0.0 -> #0.0
[VTS_01_1] 08:41:31: Stream #0.1 -> #0.1
[VTS_01_1] 08:41:31: [mpeg2video @ 0x36ecc00]Using pulldown for PAL->NTSC.
[VTS_01_1] 08:41:31: Press [q] to stop encoding
[VTS_01_1] 08:41:51: video:31303kB audio:2375kB global headers:0kB muxing overhead 1.970993%
Processing VTS_02_1.VOB
08:41:53: Converting PAL to NTSC (DVD Profile)
File Size: 0.99 GB
file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_03_1.VOB
FormatName=mpeg
Num_Frames=69076
DurationInSecs=2764
Duration=00:46:03.0
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3108
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2StreamID=[0x81]
Audio2SampleRate=48000
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
[VTS_02_1] 08:41:54: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_02_1] 08:41:54: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_02_1] 08:41:54: libavutil 49.12. 0 / 49.12. 0
[VTS_02_1] 08:41:54: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_02_1] 08:41:54: libavformat 52.23. 1 / 52.23. 1
[VTS_02_1] 08:41:54: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_02_1] 08:41:54: libswscale 0. 6. 1 / 0. 6. 1
[VTS_02_1] 08:41:54: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_02_1] 08:41:54: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_02_1.VOB':
[VTS_02_1] 08:41:54: Duration: 00:00:09.96, start: 0.280000, bitrate: 1799 kb/s
[VTS_02_1] 08:41:54: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 9000 kb/s, 25.00 tb(r)
[VTS_02_1] 08:41:54: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_02_1] 08:41:54: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_02_1_S2D.mpg':
[VTS_02_1] 08:41:54: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_02_1] 08:41:54: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_02_1] 08:41:54: Stream mapping:
[VTS_02_1] 08:41:54: Stream #0.0 -> #0.0
[VTS_02_1] 08:41:54: Stream #0.1 -> #0.1
[VTS_02_1] 08:41:54: [mpeg2video @ 0x32ecfa0]Using pulldown for PAL->NTSC.
[VTS_02_1] 08:41:54: Press [q] to stop encoding
[VTS_02_1] 08:41:56: video:2158kB audio:244kB global headers:0kB muxing overhead 3.334255%
Processing VTS_03_1.VOB
08:41:58: Converting PAL to NTSC (DVD Profile)
File Size: 966 MB
file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_03_2.VOB
FormatName=mpeg
Num_Frames=64989
DurationInSecs=2600
Duration=00:43:19.5
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3120
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
[VTS_03_1] 08:41:59: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_03_1] 08:41:59: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_03_1] 08:41:59: libavutil 49.12. 0 / 49.12. 0
[VTS_03_1] 08:41:59: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_03_1] 08:41:59: libavformat 52.23. 1 / 52.23. 1
[VTS_03_1] 08:41:59: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_03_1] 08:41:59: libswscale 0. 6. 1 / 0. 6. 1
[VTS_03_1] 08:41:59: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_03_1] 08:41:59: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_1.VOB':
[VTS_03_1] 08:41:59: Duration: 00:46:03.07, start: 0.280000, bitrate: 3108 kb/s
[VTS_03_1] 08:41:59: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
[VTS_03_1] 08:41:59: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_03_1] 08:41:59: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_03_1] 08:41:59: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_1_S2D.mpg':
[VTS_03_1] 08:41:59: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_03_1] 08:41:59: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_03_1] 08:41:59: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_03_1] 08:41:59: Stream mapping:
[VTS_03_1] 08:41:59: Stream #0.0 -> #0.0
[VTS_03_1] 08:41:59: Stream #0.1 -> #0.1
[VTS_03_1] 08:41:59: Stream #0.2 -> #0.2
[VTS_03_1] 08:41:59: [mpeg2video @ 0x3ac0bb0]Using pulldown for PAL->NTSC.
[VTS_03_1] 08:41:59: Press [q] to stop encoding
[VTS_03_1] 08:42:07: [mpeg2video @ 0x2b2d4e0]mb incr damaged
[VTS_03_1] 08:42:07: [mpeg2video @ 0x2b2d4e0]Warning MVs not available
[VTS_03_1] 08:42:07: [mpeg2video @ 0x2b2d4e0]concealing 45 DC, 45 AC, 45 MV errors
[VTS_03_1] 09:02:49: video:2023474kB audio:226660kB global headers:0kB muxing overhead 1.944771%
Processing VTS_03_2.VOB
09:02:51: Converting PAL to NTSC (DVD Profile)
File Size: 0.99 GB
file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_04_1.VOB
FormatName=mpeg
Num_Frames=57915
DurationInSecs=2317
Duration=00:38:36.6
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3707
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
[VTS_03_2] 09:02:52: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_03_2] 09:02:52: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_03_2] 09:02:52: libavutil 49.12. 0 / 49.12. 0
[VTS_03_2] 09:02:52: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_03_2] 09:02:52: libavformat 52.23. 1 / 52.23. 1
[VTS_03_2] 09:02:52: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_03_2] 09:02:52: libswscale 0. 6. 1 / 0. 6. 1
[VTS_03_2] 09:02:52: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_03_2] 09:02:52: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_2.VOB':
[VTS_03_2] 09:02:52: Duration: 00:43:19.58, start: 2763.352000, bitrate: 3120 kb/s
[VTS_03_2] 09:02:52: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
[VTS_03_2] 09:02:52: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_03_2] 09:02:52: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_03_2] 09:02:52: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_2_S2D.mpg':
[VTS_03_2] 09:02:52: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_03_2] 09:02:52: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_03_2] 09:02:52: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_03_2] 09:02:52: Stream mapping:
[VTS_03_2] 09:02:52: Stream #0.0 -> #0.0
[VTS_03_2] 09:02:52: Stream #0.1 -> #0.1
[VTS_03_2] 09:02:52: Stream #0.2 -> #0.2
[VTS_03_2] 09:02:52: [mpeg2video @ 0x18be570]Using pulldown for PAL->NTSC.
[VTS_03_2] 09:02:52: Press [q] to stop encoding
[VTS_03_2] 09:21:18: [dvd @ 0x18c2d40]buffer underflow i=1 bufi=1637 size=1792
[VTS_03_2] 09:22:04: video:1902243kB audio:213248kB global headers:0kB muxing overhead 1.948279%
Processing VTS_04_1.VOB
09:22:05: Converting PAL to NTSC (DVD Profile)
File Size: 0.99 GB
file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_04_2.VOB
FormatName=mpeg
Num_Frames=57252
DurationInSecs=2291
Duration=00:38:10.1
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3750
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
[VTS_04_1] 09:22:07: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_04_1] 09:22:07: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_04_1] 09:22:07: libavutil 49.12. 0 / 49.12. 0
[VTS_04_1] 09:22:07: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_04_1] 09:22:07: libavformat 52.23. 1 / 52.23. 1
[VTS_04_1] 09:22:07: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_04_1] 09:22:07: libswscale 0. 6. 1 / 0. 6. 1
[VTS_04_1] 09:22:07: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_04_1] 09:22:07: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_1.VOB':
[VTS_04_1] 09:22:07: Duration: 00:38:36.60, start: 0.280000, bitrate: 3707 kb/s
[VTS_04_1] 09:22:07: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
[VTS_04_1] 09:22:07: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_1] 09:22:07: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_1] 09:22:07: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_1_S2D.mpg':
[VTS_04_1] 09:22:07: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_04_1] 09:22:07: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_1] 09:22:07: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_1] 09:22:07: Stream mapping:
[VTS_04_1] 09:22:07: Stream #0.0 -> #0.0
[VTS_04_1] 09:22:07: Stream #0.1 -> #0.1
[VTS_04_1] 09:22:07: Stream #0.2 -> #0.2
[VTS_04_1] 09:22:07: [mpeg2video @ 0x37b1ec0]Using pulldown for PAL->NTSC.
[VTS_04_1] 09:22:07: Press [q] to stop encoding
[VTS_04_1] 09:39:03: [mpeg2video @ 0x264d4e0]ac-tex damaged at 37 27
[VTS_04_1] 09:39:03: [mpeg2video @ 0x264d4e0]Warning MVs not available
[VTS_04_1] 09:39:03: [mpeg2video @ 0x264d4e0]concealing 405 DC, 405 AC, 405 MV errors
[VTS_04_1] 09:39:03: video:1678856kB audio:190026kB global headers:0kB muxing overhead 1.948105%
Processing VTS_04_2.VOB
09:39:05: Converting PAL to NTSC (DVD Profile)
File Size: 330 MB
file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_04_3.VOB
FormatName=mpeg
Num_Frames=19970
DurationInSecs=799
Duration=00:13:18.8
VideoFFSTNum=2
Width=720
Height=576
Standard=PAL
BitRate=3468
AudioStreamCount=2
Audio1FFSTNum=0
Audio1StreamID=[0x81]
Audio1Codec=ac3
Audio1BitRate=224
Audio1Channels=2
Audio2FFSTNum=1
Audio2StreamID=[0x80]
Audio2Codec=ac3
Audio2BitRate=448
Audio2Channels=6
[VTS_04_2] 09:39:06: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_04_2] 09:39:06: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_04_2] 09:39:06: libavutil 49.12. 0 / 49.12. 0
[VTS_04_2] 09:39:06: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_04_2] 09:39:06: libavformat 52.23. 1 / 52.23. 1
[VTS_04_2] 09:39:06: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_04_2] 09:39:06: libswscale 0. 6. 1 / 0. 6. 1
[VTS_04_2] 09:39:06: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_04_2] 09:39:06: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_2.VOB':
[VTS_04_2] 09:39:06: Duration: 00:38:10.11, start: 2316.792000, bitrate: 3750 kb/s
[VTS_04_2] 09:39:06: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
[VTS_04_2] 09:39:06: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_2] 09:39:06: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_2] 09:39:06: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_2_S2D.mpg':
[VTS_04_2] 09:39:06: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_04_2] 09:39:06: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_2] 09:39:06: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_2] 09:39:06: Stream mapping:
[VTS_04_2] 09:39:06: Stream #0.0 -> #0.0
[VTS_04_2] 09:39:06: Stream #0.1 -> #0.1
[VTS_04_2] 09:39:06: Stream #0.2 -> #0.2
[VTS_04_2] 09:39:06: [mpeg2video @ 0x30fec10]Using pulldown for PAL->NTSC.
[VTS_04_2] 09:39:06: Press [q] to stop encoding
[VTS_04_2] 09:56:22: video:1677648kB audio:187862kB global headers:0kB muxing overhead 1.942952%
Processing VTS_04_3.VOB
09:56:25: Converting PAL to NTSC (DVD Profile)
[VTS_04_3] 09:56:26: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_04_3] 09:56:26: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_04_3] 09:56:26: libavutil 49.12. 0 / 49.12. 0
[VTS_04_3] 09:56:26: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_04_3] 09:56:26: libavformat 52.23. 1 / 52.23. 1
[VTS_04_3] 09:56:26: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_04_3] 09:56:26: libswscale 0. 6. 1 / 0. 6. 1
[VTS_04_3] 09:56:26: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_04_3] 09:56:26: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_3.VOB':
[VTS_04_3] 09:56:26: Duration: 00:13:18.81, start: 4606.936000, bitrate: 3468 kb/s
[VTS_04_3] 09:56:26: Stream #0.0[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_3] 09:56:26: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_3] 09:56:26: Stream #0.2[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
[VTS_04_3] 09:56:26: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_3_S2D.mpg':
[VTS_04_3] 09:56:26: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_04_3] 09:56:26: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_3] 09:56:26: Stream #0.2: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_3] 09:56:26: Stream mapping:
[VTS_04_3] 09:56:26: Stream #0.2 -> #0.0
[VTS_04_3] 09:56:26: Stream #0.0 -> #0.1
[VTS_04_3] 09:56:26: Stream #0.1 -> #0.2
[VTS_04_3] 09:56:26: [mpeg2video @ 0x37f3fe0]Using pulldown for PAL->NTSC.
[VTS_04_3] 09:56:26: Press [q] to stop encoding
[VTS_04_3] 10:02:18: video:583352kB audio:65532kB global headers:0kB muxing overhead 1.933720%
10:02:19: Done: Processing assets for DVD creation
Authoring DVD Folders
10:02:19: Creating TitleSet # 1
10:02:19: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
10:02:19: -->: DVDFolders creating VTS
10:02:19: -->: VTS 01
10:02:19:
DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_0_S2D.mpg...
10:02:20:
DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_1_S2D.mpg...
10:02:23:
DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_02_1_S2D.mpg...
10:02:23:
DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_1_S2D.mpg...
10:04:32:
DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_2_S2D.mpg...
10:06:14:
DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_1_S2D.mpg...
10:07:36:
DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_2_S2D.mpg...
10:09:19:
DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_3_S2D.mpg...
Drive C: has only 865 MB free.
10:09:54:
ChrissyBoy posted 2009 Oct 14 07:11
Can you try omitting VTS_01_0.VOB as i think this a menu and could well be causing the problem?
VHSonDVD posted 2009 Oct 14 07:14
OK will do - I think you could be right. Thanks for fast response Chrissyboy.
VHSonDVD posted 2009 Oct 14 09:53
"Can you try omitting VTS_01_0.VOB as i think this a menu and could well be causing the problem? "
I did that and it crashed in exactly the same place 50% of the way through Titleset #1.
I just did another quick test using just one file of the set: VTS_01_1.VOB. This worked fine and the resultant DVD is another pre-movie intro video sequence so I know I can exclude that too if I can get the whole thing to convert.
By the way when I add the assets in to SVCD2DVD some are not imported (i.e. rejected by your program) e.g. VTS_TS.VOB and VTS_02_0.VOB. 4 files in total each the same size - 154Kb.
Here are the error message and associoated log file below again.
Build: 2.5.5030.0
Source: SVCD2DVD
InnerException:
Title: 2.5
Version: 2.5.5030.0
Version : 6.0.6001
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Free Physical Memory: 350 MB
Total Virtual Memory: 2.23 GB
Free Virtual Memory: 1.39 GB
CPU Speed: 2GHz
CPU FSB: 200MHz
Video Ram: 224 MB
Status: OK
DeviceID: C:
FileSystem: NTFS
FreeSpace: 25.0 GB
<SVCD2DVD DateTime="14/10/2009 13:51:09" Filename="C:\Users\temp\Documents\NTSC conversion files\if tomorrow comes part 2.s2d">
<AssetSet>
<Asset ID="ac1b461f-f9d8-40fb-9a83-e11b42500857" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_01_1.VOB" />
<Asset ID="cae91ff4-dae9-48f1-82fa-c311e10cf638" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_02_1.VOB" />
<Asset ID="5646749f-d996-4a9d-b909-7e5181280de2" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_03_1.VOB" />
<Asset ID="76f5eccf-a2c9-4bc8-b687-97fbcf38eae0" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_03_2.VOB" />
<Asset ID="aee66c4e-7a36-40ac-87af-b0345157be27" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_1.VOB" />
<Asset ID="1802acdc-113f-4e07-9827-18f8c991c4f7" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_2.VOB" />
<Asset ID="f6ac670c-9eb3-41b4-aca8-fb0a369b23b8" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_3.VOB" />
</AssetSet>
<DVDStructure>
<TitleSet Name="VTS_01_1" PostCmd="" MenuButtonType="0">
<MenuButton X1="0" Y1="0" X2="195" Y2="58" FontFamily="Arial Unicode MS" FontSize="27.75" FontStyle="3">VTS_01_1</MenuButton>
<Title Name="VTS_01_1.VOB" AssetID="ac1b461f-f9d8-40fb-9a83-e11b42500857" MplexOffset="0" />
<Title Name="VTS_02_1.VOB" AssetID="cae91ff4-dae9-48f1-82fa-c311e10cf638" MplexOffset="0" />
<Title Name="VTS_03_1.VOB" AssetID="5646749f-d996-4a9d-b909-7e5181280de2" MplexOffset="0" />
<Title Name="VTS_03_2.VOB" AssetID="76f5eccf-a2c9-4bc8-b687-97fbcf38eae0" MplexOffset="0" />
<Title Name="VTS_04_1.VOB" AssetID="aee66c4e-7a36-40ac-87af-b0345157be27" MplexOffset="0" />
<Title Name="VTS_04_2.VOB" AssetID="1802acdc-113f-4e07-9827-18f8c991c4f7" MplexOffset="0" />
<Title Name="VTS_04_3.VOB" AssetID="f6ac670c-9eb3-41b4-aca8-fb0a369b23b8" MplexOffset="0" />
</TitleSet>
<DVDMenu Normal="-1" Highlight="-32640" Active="-65536" ShowPlayAllButton="True" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Users\temp\Pictures\if tomorrow comes.jpg" AudioPath="">
<PlayAllButton X1="202" Y1="482" X2="518" Y2="540" FontFamily="Arial Unicode MS" FontSize="27.75" FontStyle="3">Play All episodes</PlayAllButton>
</DVDMenu>
</DVDStructure>
<Settings>
<General InitialAssetFolder="C:\Users\temp\Documents\NTSC master" InitialDVDFolder="C:\Users\temp\Documents\NTSC conversion files" OutputFolderName="If Tomorrow Comes NTSC Master DVD" InitialProjectFolder="C:\Users\temp\Documents\NTSC conversion files" InitialMenuBackgroundFolder="C:\Users\temp\Documents\NTSC conversion files" DeleteS2DFiles="True" UseDVDShrink="False" />
</Settings>
</SVCD2DVD>
File Size: 25.1 MB
FormatName=mpeg
Num_Frames=1084
DurationInSecs=44
Duration=00:00:43.3
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=4869
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
13:51:09: Converting PAL to NTSC (DVD Profile)
File Size: 2.13 MB
FormatName=mpeg
Num_Frames=249
DurationInSecs=10
Duration=00:00:09.9
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=1799
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=224
Audio1Channels=2
[VTS_01_1] 13:51:09: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_01_1] 13:51:09: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_01_1] 13:51:09: libavutil 49.12. 0 / 49.12. 0
[VTS_01_1] 13:51:09: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_01_1] 13:51:09: libavformat 52.23. 1 / 52.23. 1
[VTS_01_1] 13:51:09: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_01_1] 13:51:09: libswscale 0. 6. 1 / 0. 6. 1
[VTS_01_1] 13:51:09: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_01_1] 13:51:09: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_1.VOB':
[VTS_01_1] 13:51:09: Duration: 00:00:43.39, start: 0.280000, bitrate: 4869 kb/s
[VTS_01_1] 13:51:09: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8000 kb/s, 25.00 tb(r)
[VTS_01_1] 13:51:09: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_01_1] 13:51:09: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_1_S2D.mpg':
[VTS_01_1] 13:51:09: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_01_1] 13:51:09: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_01_1] 13:51:09: Stream mapping:
[VTS_01_1] 13:51:09: Stream #0.0 -> #0.0
[VTS_01_1] 13:51:09: Stream #0.1 -> #0.1
[VTS_01_1] 13:51:09: [mpeg2video @ 0x360cc00]Using pulldown for PAL->NTSC.
[VTS_01_1] 13:51:09: Press [q] to stop encoding
[VTS_01_1] 13:51:30: video:31303kB audio:2375kB global headers:0kB muxing overhead 1.970993%
13:51:31: Converting PAL to NTSC (DVD Profile)
File Size: 0.99 GB
FormatName=mpeg
Num_Frames=69076
DurationInSecs=2764
Duration=00:46:03.0
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3108
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
[VTS_02_1] 13:51:32: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_02_1] 13:51:32: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_02_1] 13:51:32: libavutil 49.12. 0 / 49.12. 0
[VTS_02_1] 13:51:32: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_02_1] 13:51:32: libavformat 52.23. 1 / 52.23. 1
[VTS_02_1] 13:51:32: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_02_1] 13:51:32: libswscale 0. 6. 1 / 0. 6. 1
[VTS_02_1] 13:51:32: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_02_1] 13:51:32: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_02_1.VOB':
[VTS_02_1] 13:51:32: Duration: 00:00:09.96, start: 0.280000, bitrate: 1799 kb/s
[VTS_02_1] 13:51:32: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 9000 kb/s, 25.00 tb(r)
[VTS_02_1] 13:51:32: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_02_1] 13:51:32: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_02_1_S2D.mpg':
[VTS_02_1] 13:51:32: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_02_1] 13:51:32: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_02_1] 13:51:32: Stream mapping:
[VTS_02_1] 13:51:32: Stream #0.0 -> #0.0
[VTS_02_1] 13:51:32: Stream #0.1 -> #0.1
[VTS_02_1] 13:51:32: [mpeg2video @ 0x30ecfa0]Using pulldown for PAL->NTSC.
[VTS_02_1] 13:51:32: Press [q] to stop encoding
[VTS_02_1] 13:51:34: video:2158kB audio:244kB global headers:0kB muxing overhead 3.334255%
13:51:36: Converting PAL to NTSC (DVD Profile)
File Size: 966 MB
FormatName=mpeg
Num_Frames=64989
DurationInSecs=2600
Duration=00:43:19.5
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3120
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
[VTS_03_1] 13:51:37: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_03_1] 13:51:37: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_03_1] 13:51:37: libavutil 49.12. 0 / 49.12. 0
[VTS_03_1] 13:51:37: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_03_1] 13:51:37: libavformat 52.23. 1 / 52.23. 1
[VTS_03_1] 13:51:37: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_03_1] 13:51:37: libswscale 0. 6. 1 / 0. 6. 1
[VTS_03_1] 13:51:37: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_03_1] 13:51:37: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_1.VOB':
[VTS_03_1] 13:51:37: Duration: 00:46:03.07, start: 0.280000, bitrate: 3108 kb/s
[VTS_03_1] 13:51:37: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
[VTS_03_1] 13:51:37: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_03_1] 13:51:37: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_03_1] 13:51:37: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_1_S2D.mpg':
[VTS_03_1] 13:51:37: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_03_1] 13:51:37: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_03_1] 13:51:37: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_03_1] 13:51:37: Stream mapping:
[VTS_03_1] 13:51:37: Stream #0.0 -> #0.0
[VTS_03_1] 13:51:37: Stream #0.1 -> #0.1
[VTS_03_1] 13:51:37: Stream #0.2 -> #0.2
[VTS_03_1] 13:51:37: [mpeg2video @ 0x36e0bb0]Using pulldown for PAL->NTSC.
[VTS_03_1] 13:51:37: Press [q] to stop encoding
[VTS_03_1] 13:51:45: [mpeg2video @ 0x2a1d4e0]mb incr damaged
[VTS_03_1] 13:51:45: [mpeg2video @ 0x2a1d4e0]Warning MVs not available
[VTS_03_1] 13:51:45: [mpeg2video @ 0x2a1d4e0]concealing 45 DC, 45 AC, 45 MV errors
[VTS_03_1] 14:12:01: video:2023474kB audio:226660kB global headers:0kB muxing overhead 1.944771%
14:12:02: Converting PAL to NTSC (DVD Profile)
File Size: 0.99 GB
FormatName=mpeg
Num_Frames=57915
DurationInSecs=2317
Duration=00:38:36.6
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3707
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
[VTS_03_2] 14:12:04: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_03_2] 14:12:04: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_03_2] 14:12:04: libavutil 49.12. 0 / 49.12. 0
[VTS_03_2] 14:12:04: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_03_2] 14:12:04: libavformat 52.23. 1 / 52.23. 1
[VTS_03_2] 14:12:04: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_03_2] 14:12:04: libswscale 0. 6. 1 / 0. 6. 1
[VTS_03_2] 14:12:04: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_03_2] 14:12:04: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_2.VOB':
[VTS_03_2] 14:12:04: Duration: 00:43:19.58, start: 2763.352000, bitrate: 3120 kb/s
[VTS_03_2] 14:12:04: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
[VTS_03_2] 14:12:04: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_03_2] 14:12:04: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_03_2] 14:12:04: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_2_S2D.mpg':
[VTS_03_2] 14:12:04: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_03_2] 14:12:04: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_03_2] 14:12:04: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_03_2] 14:12:04: Stream mapping:
[VTS_03_2] 14:12:04: Stream #0.0 -> #0.0
[VTS_03_2] 14:12:04: Stream #0.1 -> #0.1
[VTS_03_2] 14:12:04: Stream #0.2 -> #0.2
[VTS_03_2] 14:12:04: [mpeg2video @ 0x302e570]Using pulldown for PAL->NTSC.
[VTS_03_2] 14:12:04: Press [q] to stop encoding
[VTS_03_2] 14:30:09: [dvd @ 0x3032d40]buffer underflow i=1 bufi=1637 size=1792
[VTS_03_2] 14:30:56: video:1902243kB audio:213248kB global headers:0kB muxing overhead 1.948279%
14:30:58: Converting PAL to NTSC (DVD Profile)
File Size: 0.99 GB
FormatName=mpeg
Num_Frames=57252
DurationInSecs=2291
Duration=00:38:10.1
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3750
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
[VTS_04_1] 14:30:59: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_04_1] 14:30:59: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_04_1] 14:30:59: libavutil 49.12. 0 / 49.12. 0
[VTS_04_1] 14:30:59: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_04_1] 14:30:59: libavformat 52.23. 1 / 52.23. 1
[VTS_04_1] 14:30:59: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_04_1] 14:30:59: libswscale 0. 6. 1 / 0. 6. 1
[VTS_04_1] 14:30:59: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_04_1] 14:30:59: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_1.VOB':
[VTS_04_1] 14:30:59: Duration: 00:38:36.60, start: 0.280000, bitrate: 3707 kb/s
[VTS_04_1] 14:30:59: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
[VTS_04_1] 14:30:59: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_1] 14:30:59: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_1] 14:30:59: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_1_S2D.mpg':
[VTS_04_1] 14:30:59: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_04_1] 14:30:59: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_1] 14:30:59: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_1] 14:30:59: Stream mapping:
[VTS_04_1] 14:30:59: Stream #0.0 -> #0.0
[VTS_04_1] 14:30:59: Stream #0.1 -> #0.1
[VTS_04_1] 14:30:59: Stream #0.2 -> #0.2
[VTS_04_1] 14:30:59: [mpeg2video @ 0x3631ec0]Using pulldown for PAL->NTSC.
[VTS_04_1] 14:30:59: Press [q] to stop encoding
[VTS_04_1] 14:47:47: [mpeg2video @ 0x28bd4e0]ac-tex damaged at 37 27
[VTS_04_1] 14:47:47: [mpeg2video @ 0x28bd4e0]Warning MVs not available
[VTS_04_1] 14:47:47: [mpeg2video @ 0x28bd4e0]concealing 405 DC, 405 AC, 405 MV errors
[VTS_04_1] 14:47:47: video:1678856kB audio:190026kB global headers:0kB muxing overhead 1.948105%
14:47:47: Converting PAL to NTSC (DVD Profile)
File Size: 330 MB
FormatName=mpeg
Num_Frames=19970
DurationInSecs=799
Duration=00:13:18.8
VideoFFSTNum=2
Width=720
Height=576
Standard=PAL
BitRate=3468
AudioStreamCount=2
Audio1FFSTNum=0
Audio1Codec=ac3
Audio1BitRate=224
Audio1Channels=2
Audio2FFSTNum=1
Audio2Codec=ac3
Audio2BitRate=448
Audio2Channels=6
[VTS_04_2] 14:47:49: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_04_2] 14:47:49: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_04_2] 14:47:49: libavutil 49.12. 0 / 49.12. 0
[VTS_04_2] 14:47:49: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_04_2] 14:47:49: libavformat 52.23. 1 / 52.23. 1
[VTS_04_2] 14:47:49: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_04_2] 14:47:49: libswscale 0. 6. 1 / 0. 6. 1
[VTS_04_2] 14:47:49: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_04_2] 14:47:49: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_2.VOB':
[VTS_04_2] 14:47:49: Duration: 00:38:10.11, start: 2316.792000, bitrate: 3750 kb/s
[VTS_04_2] 14:47:49: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
[VTS_04_2] 14:47:49: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_2] 14:47:49: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_2] 14:47:49: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_2_S2D.mpg':
[VTS_04_2] 14:47:49: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_04_2] 14:47:49: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_2] 14:47:49: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_2] 14:47:49: Stream mapping:
[VTS_04_2] 14:47:49: Stream #0.0 -> #0.0
[VTS_04_2] 14:47:49: Stream #0.1 -> #0.1
[VTS_04_2] 14:47:49: Stream #0.2 -> #0.2
[VTS_04_2] 14:47:49: [mpeg2video @ 0x2b9ec10]Using pulldown for PAL->NTSC.
[VTS_04_2] 14:47:49: Press [q] to stop encoding
[VTS_04_2] 15:05:04: video:1677648kB audio:187862kB global headers:0kB muxing overhead 1.942952%
15:05:05: Converting PAL to NTSC (DVD Profile)
[VTS_04_3] 15:05:06: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
[VTS_04_3] 15:05:06: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
[VTS_04_3] 15:05:06: libavutil 49.12. 0 / 49.12. 0
[VTS_04_3] 15:05:06: libavcodec 52. 6. 0 / 52. 6. 0
[VTS_04_3] 15:05:06: libavformat 52.23. 1 / 52.23. 1
[VTS_04_3] 15:05:06: libavdevice 52. 1. 0 / 52. 1. 0
[VTS_04_3] 15:05:06: libswscale 0. 6. 1 / 0. 6. 1
[VTS_04_3] 15:05:06: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
[VTS_04_3] 15:05:06: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_3.VOB':
[VTS_04_3] 15:05:06: Duration: 00:13:18.81, start: 4606.936000, bitrate: 3468 kb/s
[VTS_04_3] 15:05:06: Stream #0.0[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_3] 15:05:06: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_3] 15:05:06: Stream #0.2[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
[VTS_04_3] 15:05:06: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_3_S2D.mpg':
[VTS_04_3] 15:05:06: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
[VTS_04_3] 15:05:06: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
[VTS_04_3] 15:05:06: Stream #0.2: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[VTS_04_3] 15:05:06: Stream mapping:
[VTS_04_3] 15:05:06: Stream #0.2 -> #0.0
[VTS_04_3] 15:05:06: Stream #0.0 -> #0.1
[VTS_04_3] 15:05:06: Stream #0.1 -> #0.2
[VTS_04_3] 15:05:06: [mpeg2video @ 0x37d3fe0]Using pulldown for PAL->NTSC.
[VTS_04_3] 15:05:06: Press [q] to stop encoding
[VTS_04_3] 15:10:58: video:583352kB audio:65532kB global headers:0kB muxing overhead 1.933720%
15:10:59: Done: Processing assets for DVD creation
15:10:59: Creating TitleSet # 1
15:10:59: SVCD2DVD: DVDfolders
15:10:59: -->: DVDFolders creating VTS
15:10:59: -->: VTS 01
15:10:59:
15:11:07:
15:11:07:
15:13:07:
15:14:44:
15:16:10:
15:17:39:
15:18:12:
ChrissyBoy posted 2009 Oct 14 12:41
I think the issue is mixing of the old titlesets into a single titleset:
File Size: 25.1 MB
FormatName=mpeg
Num_Frames=1084
DurationInSecs=44
Duration=00:00:43.3
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=4869
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
File Size: 2.13 MB
FormatName=mpeg
Num_Frames=249
DurationInSecs=10
Duration=00:00:09.9
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=1799
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=224
Audio1Channels=2
File Size: 0.99 GB
FormatName=mpeg
Num_Frames=69076
DurationInSecs=2764
Duration=00:46:03.0
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3108
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
File Size: 966 MB
FormatName=mpeg
Num_Frames=64989
DurationInSecs=2600
Duration=00:43:19.5
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3120
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
File Size: 0.99 GB
FormatName=mpeg
Num_Frames=57915
DurationInSecs=2317
Duration=00:38:36.6
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3707
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
File Size: 0.99 GB
FormatName=mpeg
Num_Frames=57252
DurationInSecs=2291
Duration=00:38:10.1
VideoFFSTNum=0
Width=720
Height=576
Standard=PAL
BitRate=3750
AudioStreamCount=2
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
Audio2FFSTNum=2
Audio2Codec=ac3
Audio2BitRate=224
Audio2Channels=2
File Size: 330 MB
FormatName=mpeg
Num_Frames=19970
DurationInSecs=799
Duration=00:13:18.8
VideoFFSTNum=2
Width=720
Height=576
Standard=PAL
BitRate=3468
AudioStreamCount=2
Audio1FFSTNum=0
Audio1Codec=ac3
Audio1BitRate=224
Audio1Channels=2
Audio2FFSTNum=1
Audio2Codec=ac3
Audio2BitRate=448
Audio2Channels=6
The number of audio streams differ in the assets and that is not allowed in a single titleset.
So basically you need to seperate out the titles based on audio/video attributes:
Title: VTS_01_1.VOB (ac3 5.1)
Title: VTS_02_1.VOB (ac3 2.0)
Title: VTS_03_X.VOB (2 AC3 streams)
Title: VTS_04_x.VOB (2 AC3 streams)
This is probably why it was authored this way in the first instance.
Anyway the Play All Menu button will "string them together".
VHSonDVD posted 2009 Oct 15 01:59
I got rid of the rogue different audio segments (which were all pre-movie crap anyway and the conversion worked perfectly.
This has given a bit more confidence to get in to the nuts and bolts of how this all works so many thanks Chrissyboy for your patient and fast responses.
You have authored a great product, the results from which will make folk all over the world very happy!
ChrissyBoy posted 2009 Oct 15 02:31
Nice one!
dunncha posted 2009 Oct 26 08:15
Hi all
I have this problem listed above and the solution looks a good one but...
I am putting together a compilation of music video's taken from several different places. In ripping these video's I often had to select different audio streams as occasionally the commentary would come up over the music.
I now have all the Mpg's with the audio's the way I want I want using Vob2mpg but I have different d audio streams mixed throughout the collection.
Is their a way I can run a script across all the files to 'Line up' all the audio streams or will I have to go a re-rip all the video's…….. or is there a way I could find out which mpg's are causing the issue.
I could use the 'play all' option but that would make the menu a lot longer than would really suit. Or is there a way I can create submenu's.
Many thanks in advance
dunncha
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
