Forum archive - Converter with these 2 features...
http://www.supermediastore.com/
Forum Archive Home -> Video Conversion -> Converter with these 2 features...
marioval posted 2009 Nov 05 10:29
I'm looking for a all-in-one video converter that has the following 2 features:
1. A preview window showing how the output file will look in terms of aspect ratio, crop, pad, etc. (Xmedia Recode has this)
2. An option to select the output file size which would automatically adjust the bitrate accordingly.
Baldrick posted 2009 Nov 05 11:40
Xvid4psp will show the preview directly and you can set the output file size if you change the encoding mode to "2-pass size". You find the crop, pad, aspect ratio functions under Video->Resolution/Aspect. But it may be a bit buggy under some systems.
marioval posted 2009 Nov 05 12:51
Thanks, i'll definitely check that out..... What about for 1 pass encoding?
usta posted 2009 Nov 06 03:04
I think 1pass will show only an approximation of the output size.
marioval posted 2009 Nov 06 08:03
I just realized in Xmedia Recode, I can hightlight the video then choose "Options > Bitrate Calculator" then specify the output size and the bitrate will adjust. The few that I have done have came out larger than what I specify so it is just an estimate so I just specify a bit smaller size than what I really want. Thanks to all for the assistance.
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
