Forum archive - Conversion problem - Laggy (choppy) video
http://www.supermediastore.com/
Forum Archive Home -> Video Conversion -> Conversion problem - Laggy (choppy) video
yaang posted 2009 Oct 30 21:05
Basically i'm just trying to reduce the size of a h.264 720p video.
I'm using Megui and constant quality profile set to 21.
Problem is the output video comes out laggy, i don't think it's because of my hardware because i can play the original file smoothly. Weird thing is i always do a test run first to see if a set-up everything correctly by encoding the first 30 seconds at first and the motion was smooth. But when i finished encoding the whole thing it was laggy. I don't know how to describe it exactly, original of the video has 23.976fps and the encoded one seems to be running with 20fps but when i check it is 23.976. Motion isn't smooth it happens in tiny tiny jumps. I hope you understand what i'm talking about :)
Heres the info of the original file :
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 10 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 33mn
Bit rate : 5 762 Kbps
Nominal bit rate : 5 908 Kbps
Width : 1 280 pixels
Height : 534 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.352
Stream size : 6.17 GiB (78%)
Writing library : x264 core 68 r1179M 96e2229
Encoding settings : cabac=1 / ref=10 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=esa / subme=9 / psy_rd=1.0:0.1 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=12 / nr=0 / decimate=1 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=5908 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80
Language : English
Here's my re-encoded verison:
Video
Format : AVC
Format profile : High@L3.1
Format settings, ReFrames : 2 frames
Codec ID : avc1
Duration : 2h 33mn
Bit rate mode : Variable
Bit rate : 2 206 Kbps
Maximum bit rate : 15.9 Mbps
Height : 534 pixels
Frame rate mode : Constant
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.135
Stream size : 2.37 GiB (89%)
Writing library : x264 core 68 r1183M f21daff
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=4 / psy_rd=0.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=crf / crf=21.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Encoded date : UTC 2009-10-29 22:12:01
Tagged date : UTC 2009-10-29 22:15:23
Can somebody point out what i'm doing wrong ?
yaang posted 2009 Nov 01 05:19
Someone pointed out that my reference frames is set to 2 in the re-encoded version can it be the source of the problem ?
poisondeathray posted 2009 Nov 01 09:02
yaang :
Very unlikely to be the cause
What device or software are you using to play? The re-encoded video doesn't have any vbv buffer. This should matter if on a PC with decent specs, but will be a problem on devices
What did you do with the audio? If you re-encoded and don't have a proper decoder that could explain why
What container? .mp4 ? .mkv ? If you don't have a proper splitter that might cause it
What happens with different media players? Try KMplayer or MPCHC or VLC
yaang posted 2009 Nov 04 12:36
I'm using media player classic with k-lite mega codec pack.
Audio was converted to Nero AAC LC-256kbps multichannel but i tried with no audio too so that can't be the problem.
Container is .mp4
I tried re-encoding with tmpgenc xpress 4.0 with the same settings except i left the deinterlace method on deinterlace when necessary and it came out perfect. So i decided it's a deinterlacing issue. After i checked megui with this on mind i've noticed megui recognizes the video to be 23.976fps NTSC. I changed the output fps to be 29.97 and the problem was solved. I don't understand how that happened though since Gspot tell me video is 23.976 progressive. Is it possible for a video to be both progressive and interlaced ?
Login/Register to our forum to be able to post here.
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
