Forum Archive Home -> Mac -> cant trim/cut mpg in QT-pro
| cant trim/cut mpg in QT-pro |
| Kevlin posted 2008 Aug 17 11:37 |
| I just switched from PC to Mac and is a little disoriented. I collect music videos and use these to make quizes among other things. For this I need to be able to cut (trim as QT-pro calls it) parts of the file but with mpg there is no trimming option. The start and stop blocks represented in the movie timeline (bottom of the screen) are simply not there.
I have the mpeg-2 plug-in installed as well. Is there anyone who have a solution for this? Either in QT-pro or another program that I could use instead? Thank you /Kim |
| ffooky posted 2008 Aug 17 12:31 |
| MPEG Streamclip will do the job. |
| Kevlin posted 2008 Aug 17 12:57 |
| Thank you kindly for the fast answer. Works perfect.
hat of for Ffooky /K |
| ffooky posted 2008 Aug 17 13:25 |
| Pleasure :) |
Login/Register to our forum to be able to post here.
