Forum archive - Can't get sound from MPEG in F.C.
http://www.supermediastore.com/
Forum Archive Home -> Mac -> Can't get sound from MPEG in F.C.
Tom in HD posted 2010 Jan 14 14:44
Hello
I cannot get sound out of my MPEG video files. They were videos shot on a Sony digital Still camera that also does video. For some reason, they have no sound when I import them into Final Cut. I also cannot even import the files into I-movie. It won't allow me to do it. Is there some way I can edit these and have the sound?
T in HD :?
Baldrick posted 2010 Jan 14 15:39
What audio codec in the mpg file? Identify using mediainfo.
Or try mpeg streamclip to convert the mpg to a format that final cut accepts.
rumplestiltskin posted 2010 Jan 14 18:44
Try using MPEG Streamclip (you should already have Apple's MPEG2 codec if you have FCP installed) to convert the MPEG file to Apple Intermediate Codec. This will let you import it into FCP and not introduce any add'l compression artifacts. The audio should also work fine.
Tom in HD posted 2010 Jan 14 22:40
Thanks.
I've had some success.
T in HD :P
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
