VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Mac -> Burning .avi to DVD
Burning .avi to DVD
monieeka posted 2008 Aug 11 21:59
I'm trying to burn some .avi files on my MacBook to DVD to play on my TV (I have a Sony DVP-C660 DVD player). They all play in Quicktime, so I have the right codecs. I've tried just burning with the DVD-Video tab in Popcorn, and even making a disk image, ripping it using MacTheRipper, and burning using the Video_TS tab, but no matter what I try, my DVD player comes up with "Playback prohibited by area limitations." How do I fix this, or, how do I burn .avi files to a DVD so they'll play on my TV?
guns1inger posted 2008 Aug 11 22:43
When Sony says "Playback Prohibited By Area Limitations" is is usually telling you that you are trying to play PAL video in an NTSC only player. PCs (even Macs) do not have a PAL/NTSC problem. Either get a better player (but them you might also have to change your TV as well) or convert the video to NTSC (should be an option in your conversion program) and live the fact it will probably be jerky during pans and zooms.
monieeka posted 2008 Aug 11 23:54
How can I convert to NTSC in Popcorn? (I'm a total tech noob haha)
guns1inger posted 2008 Aug 12 01:25
I have no idea - I don't have a Mac. You would be looking for a field marked Format or TV Format, with PAL, NTSC and/or Auto as the options. If you can't find it then you may have to resort to - gasp ! shock ! horror ! - reading the help files.
nerys posted 2008 Sep 10 21:50
Where do you live? I see in your title USA you DO live in the US right? its possible either your player is another region OR your mac drive is "set" to a different region. ??
Most dvd players will internally take care of pal or ntsc anymore you should not have that as a problem unless you have an oddball DVD player. I would try ripping a movie that already works in the dvd player.
rip 10 minutes of it. convert to AVI. then run it through the exact steps you use for the first DVD and see what happens.
If it fails to play then you know the "software" is doing something goofy and not making a compatible disk.
Frobozz posted 2008 Sep 11 18:37
monieeka :
If you have NTSC set in Popcorn Preferences and you feed Popcorn a PAL video file then Popcorn will ask if you really want to convert it. (Note: this is not the case when trying to copy a PAL DVD or VIDEO_TS folder to a NTSC DVD which requires some additional stesp).
Insert your burned DVD and select DVD with the top button of the Popcorn Media Browser. Double-click on what appears in the browser window. Now place the cursor over one of the titles that appears in the browser. A window will appear that describes the specs of the video including whether it is NTSC or PAL.
Does the burned disc play on your Mac using DVD Player? What are the other specs that Popcorn reports for the video? What brand of discs are you using?
Herve posted 2008 Sep 12 06:40
monieeka :
my 2 cents...
there is some DVD areas (depending on your country)
to enable (or disable) use mydvdedit
double-click on an .IFO file inside your resulting VIDEO_TS (...will open mydvdedit)
in mydvdedit: bottom center, ther's a field with vertical tabs, clic on "DVD"
enable checkboxes 1 to 6, disable 7&8
save
your area is now compatible
PS: if the message ("Playback prohibited by area limitations.") was exact (and not a generic message whitout any meaning), this setting will correct it ;)
bye
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
