Forum Archive Home -> Mac -> Burn software issues
Burn software issues | ||
| RedGiant947 posted 2009 Dec 26 01:35 | ||
| I'm trying to burn a 8.5 GB double layer dvd with the Burn software, but it keeps giving me a disc drive error which doesn't occur with my 4.7 GB discs. Does anybody know the problem or if this is possible? Are there any other freeware somebody can recommend? (It seems all of the guides say to use toast, but I don't have 80 dollars to blow...) Thanks | ||
| fozzieb posted 2009 Dec 26 03:41 | ||
| Is it snow leopard you have? I have the same issue, can not burn dual layer dvd's even using toast. It all worked ok until i upgraded to Snow Leopard.
There are quite a few people with this issue. | ||
| RedGiant947 posted 2009 Dec 26 13:26 | ||
| Yes I have Snow Leopard, so that just must be the issue. Thanks for the help, hopefully somebody fixes this soon. | ||
| Herve posted 2009 Dec 27 04:41 | ||
I only use it to burn… bye and Happy Christmas | ||
| fozzieb posted 2009 Dec 27 04:52 | ||
| under Snow Leopard, liquid CD does not work with dual layer either |
Login/Register to our forum to be able to post here.
