Forum Archive Home -> Video Streaming -> brightcove.com
brightcove.com |
| u2fan480 posted 2009 Oct 22 11:00 |
| http://link.brightcove.com/services/player/bcpid38083270001?bclid ... 5614803001
I am trying to download this video (Fan rock the valley) to my desktop. I have tried all different techniques and programs that I have learned on this forum. I just cant seem to get it.. Any help would be much appreciated! |
| poisondeathray posted 2009 Oct 22 11:15 |
| This is an rtmp stream
Old versions of replay media capture work I suspect firefox with the download helper would too I uploaded it for you here http://www.mediafire.com/download.php?hkyerykkzwm Cheers |
| u2fan480 posted 2009 Oct 22 11:51 |
| poisondeathray you are TheBomb.com! i did try download helper and it did not pick it up... thank you so much. |
| lordsmurf posted 2009 Oct 22 12:24 |
| Download Helper has never really worked for me. |
| k. posted 2009 Oct 22 13:03 |
| Try the Grab Pro tool included with Orbit Downloader. Download Helper only supports http. |
| minidv2dvd posted 2009 Oct 22 13:16 |
| pdr - which version of rmc works for rtmp for you? i have v2 and can't get it. |
| poisondeathray posted 2009 Oct 22 13:26 |
| @minidv2dvd - do you remember that big hoopla where rmc became b0rked due to changing the plugins due to pressure from Adobe? There were several posts in this forum and on the rmc forum about this, if you want more info. All new versions apparently become "flashed" with a new plugin_zrtmp , plugin_zrtsp, etc...
My current version is 3.01 , plugin_zrtmp 5.2.6.9 plugin_zrtsp 1.2.6.9 There are a few other plugins, but I think those are the relevant ones What I do is configure my firewall settings so it blocks the flash, so I end up keeping the old plugin versions which seem to work ok on most stuff |
| minidv2dvd posted 2009 Oct 22 13:36 |
| ahh crud, now i do. thanks for the reminder. i checked my plugins and you're correct they have been updated without my knowing. going to try and get back the old ones.
thanks |
Login/Register to our forum to be able to post here.
