Forum Archive Home -> Blu-ray Ripping -> Blu ray to MKV / x264 stops
Blu ray to MKV / x264 stops | ||
| Dragonfiii posted 2009 Sep 12 18:48 | ||
| Hi
I have this bluray I want to make an mkv out of it, using x264.exe - I have made several other backup's like this but this disc is really annoying me. copies fine to hdd and I end up with the 20gb m2ts file, I make avs script dont want any resize or any cropping. When I start the 1st pass encode the x264.exe sometime runs to 0.6% completion and then just suddently stops, no error given. Sometimes I make it to 6.8% and it stops, no error given. Does anyone have an idea what the problem could be? never happend to me before when making others. I do all the stuff the excat same as I have done before but still it just stops all of the sudden Hope someone has some idea's what it could be Thanks in advance | ||
| poisondeathray posted 2009 Sep 12 18:52 | ||
| What x264.exe version? Try a different build, some people reported problems with r1251 | ||
| Dragonfiii posted 2009 Sep 12 19:32 | ||
oh okay yeah iv been using 1251 but havnt had problem with it other then with this one disc, have made a few others with 1251. But i'll try with an older one | ||
| redwudz posted 2009 Sep 12 19:50 | ||
| I would try running a memory check. Sudden changes like that may be related to a failed RAM module. Memtest 86 should work for you. http://www.memtest86.com/
If not, then if it's a newer BD, maybe a decryption problem. I use AnyDVD HD and rip to my HDD for problematic discs. Then use tsMuxeR to select the main video and the desired audio track. I use them for the conversion. I've encountered a few BDs that have more than a few problems with the conversions, but none of them have stopped as you describe. :( | ||
| Dragonfiii posted 2009 Sep 13 16:50 | ||
| I have solved my problem, had to index it using VC1 indexer then I can work with it from there..
Thx for all the input! Go ahead delete this thread. |
Login/Register to our forum to be able to post here.
