Forum archive - Blu ray from f4v
http://www.supermediastore.com/
Forum Archive Home -> Authoring (Blu-ray) -> Blu ray from f4v
Blu ray from f4v
diodorus posted 2009 Oct 21 17:35
Hello,
I am new here... I'd like to author a (simple) blu-ray. The source material is .f4v files with the following specs:
Video:
H264
1280 x 720
aspect ratio = 1:1
frame rate = 23.976
Audio:
AAC
128 kbps
44100 Hz
Can I use these files without re encoding them? what program could I use?
Thanks,
diodorus
Baldrick posted 2009 Oct 21 17:39
The audio must be reconverted but the video might work without reconverting. Try multiAVCHD and see what it says.
If it wont work try an all-in-one blu-ray/avchd converter like avchdcoder, d2mp.
diodorus posted 2009 Oct 21 18:05
ok, since multiAVCHD wouldn't take f4v files as inputs, i first used avidemux and transformed the f4v's into mp4's (no re encoding, right?).
then i put the mp4 into multiAVCHD, which, as you predicted, (if i understood correctly) only re encoded the audio... i then created an iso with imgburn and it played correctly in powerdvd.
that all went too smooth, as a first experiment!!
if i now want to create a a blu ray with menus, can u recommend any software i could start playing with?
thanks!!
diodorus
edit: i have just noticed the menu section within multiAVCHD. i'll start playing with this first, but i assume it's not very versatile...
Baldrick posted 2009 Oct 21 18:17
If you use video COPY and audio COPY in avidemux there will be no reconverting, just remuxing to a mp4.
For more advanced menu creation you can use tmpgenc authoring works or http://www.videohelp.com/tools/sections/authoring-bd-hd-dvd . BUT most of them might reconvert your video....and they aren't exactly free.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
