Forum archive - BD Rebiulder x264 encoder error
http://www.supermediastore.com/
Forum Archive Home -> Blu-ray Ripping -> BD Rebiulder x264 encoder error
wulf109 posted 2009 Oct 11 19:33
I've got BD Rebuilder working on my main computer,but I can't get it to work on my other two computers. It starts to encode but I quickly get x264 encoder failed error. I've installed ffdshow,haali splitter,and Avisynth. ???????????????
mrswla posted 2009 Oct 11 20:04
Have you tried to reinstall them? I got the x264 encode once or twice and I believe I fixed it by reinstalling the "extras".
fritzi93 posted 2009 Oct 11 23:14
mrswla :
Same here. A re-install of ffdshow and Haali has fixed it for me.
wulf109 posted 2009 Oct 12 10:13
I re-installed the programs and I'm still getting the error.
ocgw posted 2009 Oct 12 14:24
wulf109 :
Try a previous version of BD Rebuilder perhaps
ocgw
peace
wulf109 posted 2009 Oct 12 15:52
Tried all the early versions back as far as beta time out permitted.
mrswla posted 2009 Oct 12 17:31
What are the titles that you are trying on the other two computers? Have you ever gotten successfull backups on those computers? What are the computers specs?
mrswla posted 2009 Oct 12 17:32
Just noticed a new version on x264 encoder has just been posted. Trying downloading that and dropping it in bdrb.
wulf109 posted 2009 Oct 12 20:43
Dropped in latest x264 but same problem,encoder failure at about 3%. My backup computers are not hooked up to the internet,could that be the problem?
ocgw posted 2009 Oct 14 10:48
wulf109 :
Are you overclocking @ all on the cpu or memory, or running tighter timings on the memory?
ocgw
peace
wulf109 posted 2009 Oct 14 14:36
I'm overclocking all three computer:
i7 2.66 to 3.6
e8400 3.0 to 4.0
AMD X4-620 2.6 to 3.3
Memory is overclocked on i7 and E8400,not the AMD x4-620,5-5-5-15 timing on the i7 and e8400,default on the AMD (1066)
BDrebulder runs fine on my i7 and it has both the CPU and memory overclocked.
ocgw posted 2009 Oct 19 14:00
wulf109 :
i7 2.66 to 3.6
e8400 3.0 to 4.0
BD Rebuilder "pegs" all your cpu cores, it is the only program I run that makes me reduce my overclock when it is hot
This could really be an OC issue
Stability when overclocking is an issue which may be solved w/ a little extra cpuv, unless temps becomes a factor
The other concern is temps it self, are you monitoring your temps?
Sometimes a little extra NBv helps because of the memory controller setting on the cpu die, also adding v to the SB or HTT bus may help
Reduce your overclock first to stock and then run BD Rebuilder again and see if it fails, if not then slowly work up a stable overclock for BD Rebuilder and note the settings
ocgw
peace
wulf109 posted 2009 Oct 19 15:11
It is an overclock problem. I dropped my AMD 620 to it's default speed of 2.6 and it encodes without issue. I have moved upto 3.2Ghz and it seems stable at that speed. I dropped the E8400 to 3.6 and it also seems stable,but it is painfully slow. You really shouldn't use anything but a quad to encode with BD Rebuilder.
mrswla posted 2009 Oct 19 15:19
Glad to hear you solved the problem. :)
ocgw posted 2009 Oct 19 16:25
wulf109 :
Tell me about it :) lol
glad you got it sorted out
ocgw
peace
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
