VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Blu-ray to AVI/MP4/MKV/WMV -> BD Codec?
BD Codec?
kinglerch posted 2008 Aug 01 14:02
I apologize in advance if this has been asked before, or this is the wrong section.
I created a BD MPEG with PCM audio using Ulead Videostudio, but when I play it the audio doesn't play at all. I also tried creating an HDDVD MPEG with PCM audio, but when I tried to play it the audio is very scratchy and the video studders a bit. This is using Windows Mediaplayer. I also noticed I couldn't convert either of these MPEGs using TMPGEnc, it just gives an unrecognizable file error.
Is some sort of codec or different type of player required to play these MPEGs? They are 1920x1080 60i with PCM audio. I have a Phenom 9750, so I assume it's not a speed issue.
kinglerch posted 2008 Aug 01 14:22
Just to clarify, Ulead Videostudio exports an MPEG-4 suitable for use on a BD or HDDVD disc (1920x1080 60i PCM) but the result is not (yet) in BD format. But for some reason, I can't play the MPEG-4...cleanly anyway. Do I need a codec to play the MPEG-4 properly with Mediaplayer or why would it not play correctly?
minidv2dvd posted 2008 Aug 01 15:40
you need a really fast computer to play hd mpeg-4.
kinglerch posted 2008 Aug 01 19:42
Strangely enough, the video plays ok, but the audio is silent or scratchy. Is LPCM non-standard?
minidv2dvd posted 2008 Aug 01 20:26
lpcm is in the hd&br specs, it shouldn't be any problem.
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
