VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Advanced Video Conversion -> batch trimming clips how ?
doggyjumper posted 2008 Sep 06 12:47
Hi
I have hundreds of clips (in one directory) that each have a associated xml file containing several details related to those clips.
one of those is a cut/trim point location (time position) .
what i need to do is physically trim those clips now based on hte data in the xml file of each clip
Source is DV , result shoudl be trimmed DV clip ( may be overwritten )
I noticed Virtualdub has jobcontrol ( like process all clipps in one directory ) so basically thats what I like to do if I can find out how to read the xml data and let VD trim and save those clips
is this the correct path to look into and if so , is it possible to script somehow the reading and trimming in batch (example apreciated) or are there other solutions available
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
