VideoHelp.com forum archive
http://www.supermediastore.com/
Forum Archive Home -> Software Playing -> AVIVO Confusion
AVIVO Confusion
jameson_uk posted 2008 Sep 07 14:50
Been reading around how AVIVO supposedly does proper upscaling however I can not figure out how this all works.
There are no AVIVO options other than things like Colour in Catalyst and from what I am seeing in various players there is no post-processing upscaling going on. I am mainly interested in MPEG2 material and using FFDShow I can see improvement but at the cost of lots of CPU usage. I am using the PowerDVD 7.3 codecs for playback but do I need PowerDVD 8 to beneft from this ?? I am using a 3650 butI dont think it makes much difference which card??
jameson_uk posted 2008 Sep 11 15:47
anyone ?
disturbed1 posted 2008 Sep 11 17:44
Your card support these AVIVO features
ATI Avivo Video Post Processor
    * Color space conversion
    * Chroma subsampling format conversion
    * Horizontal and vertical scaling
    * Gamma correction
    * Advanced vector adaptive per-pixel de-interlacing
    * De-blocking and noise reduction filtering
    * Detail enhancement
    * Inverse telecine (2:2 and 3:2 pull-down correction)
    * Bad edit correction
You have to use a supported codec in order to tap into the AVIVO processor :(.
Do a google search for avivo and codecs or something ;)
Login/Register to our forum to be able to post here.
About   Advertise   Forum Archive   RSS Feeds   Statistics
