Forum archive - .avi to .VOB format - without changing size & quolity
http://www.supermediastore.com/
Forum Archive Home -> Video Conversion -> .avi to .VOB format - without changing size & quolity
akakiami posted 2009 Nov 03 06:38
Hi All,
I've some movies in .avi format, but want to burn them as DVD disc. So need to convert them into .VOB format. I've some softs, they are doing well, but increasing the size too big. suppose in .avi format 700 MB to .VOB format 2.5 GB!!!
Even from .avi to .mpeg size also increasing too bigger!!!
So, how can make dvd of those .avi files without changing size & quality?
~r
Baldrick posted 2009 Nov 03 06:48
Just lower the video bitrate to get smaller size, in many tools can you also set the output file size. Use for example convertxtodvd, avstodvd, dvd flick.
BUT you can't keep the quality as dvd video needs higher bitrate=bigger file size to keep similar quality as avi divx/xvid/h264 video.
guns1inger posted 2009 Nov 03 06:53
If you want to keep them the same size, get a DVD player that will also play Divx/Xvid encoded avi files, or get a WDTV and a portable HDD.
if you want to put them on DVD as DVDs, then it is one movie per disc (two if you use dual layer). Generally you need 3 - 4 times the original file size when converting to mpeg-2 to come close to maintaining the original quality (low as it is).
hech54 posted 2009 Nov 03 07:00
akakiami :
That's normal.
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
