Forum Archive Home -> ffmpegX general discussion -> AVI to DVD
AVI to DVD | ||
| cpwhaley posted 2009 Sep 28 14:26 | ||
| As a newbie to this software, I'm clearly missing something in simply converting an .avi file to DVD format, so I can put it on a disk.
I'm using the "HOW TO MAKE A DVD..." guide. I choose AVI for input and DVD ffmeg for output. I don't change the in/out filenames at the top. After the encoding is done, the guide tells me that there's supposed to be a "movie.DVD" folder with AUDIO_TS and VIDEO_TS files inside. NOT on my computer there isn't. The only file created has my original file name plus a ".ts" extension. I can't do anything with that without getting some sort of invalid format message from Toast or Popcorn or the built-in Apple software. Where am I going wrong? | ||
| maruz posted 2009 Oct 01 08:11 | ||
| Have you checked the "Author as" box in the Options tab and get the drop down menu to be as DVD(VIDEO_TS)? | ||
| Case posted 2009 Oct 04 18:04 | ||
Login/Register to our forum to be able to post here.
