Thanks to PureBasic cross compiling i was able to tweak automen and porting to Linux
AutoMen 6 is here (beta.. as usually)
http://www.64k.it/andres/data/automen/automen6_x86.tar.gz
tested on Fedora 32bit, Ubuntu 9.04 32 and 64bit
need mencoder, mplayer, xterm
BHH
Results 1 to 25 of 25
HDConvertToX, AutoMen, AutoMKV Developer -
Looks just fine on Slackware with Xfce. Nice and easy GUI, and easy enough to comfigure profile.txt. Cool, and thanks
Doesn't support directories with spaces in them. Threads option doesn't seem to work
Prompts for mp4creator, but doesn't need this installed to run.
Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
Xvid is multithreaded.
Code:xvidenc (-xvidencopts) There are three modes available: constant bitrate (CBR), fixed quantiz- er and two pass. .............................................. snip .............................................. The following option is only available in the 1.2.x version of Xvid. threads=<0-n> Create n threads to run the motion estimation (default: 0). The maximum number of threads that can be used is the picture height divided by 16.
The default in Ubuntu and other Debian based distros are not multithread enabled. Plus they have a habit of not using NASM, so it's even slower.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
Originally Posted by buzzqw
If you're using an old Xvid (1.1.2/.3) specifying threads=n does nothing to it.
All the way back to mencoder 1.0rc1 (Ubuntu Fiesty 7.04)
Code:The following option is only available in the CVS version of XviD. threads=<0\-n> Create n threads to run the motion estimation (default: 0). The maximum number of threads that can be used is the picture height divided by 16.
WIth x264, it always uses more than one core no matter if it is ticked or not. With lavc it only uses one core. This is because your profile.txt has threads=auto hard coded for x264, and negates the thread option for mpeg4.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
thanks disturbed1!
learning is a never ending process!
about threads disabled i will check when home
thanks again!
BHHHDConvertToX, AutoMen, AutoMKV Developer -
Perhaps, since x264, lavc, and xvid all use threads=$, that could be a variable that can be passed? But that seems like too much of a coding change. I don't know, I'm not a programmer. Considering your profiles.txt is easy to read and change, I'm just editing it by hand.
I've been using your program to encode a few streams to xvid, lavc, and x264, and they all work!. Have to say I really do like it. This is a first for me, as I'm a command line junky.
About the directory spaces. Read from spaces, write to no spaces works. Read from no spaces, write to spaces works. Read + write to spaces, doesn't work I even did a chmod 777 on the directory so everyone has rw on it just to make sure.
Code:"/usr/bin/mencoder" -ofps 30000/1001 -vf harddup,crop=720:480:0:0,scale=656:-2,hqdn3d -sws 2 -o "/home/keith/a directory with spaces/test_automen.avi" -ovc xvid -xvidencopts bitrate=1682:max_bframes=2:bquant_ratio=162:bquant_offset=100:vhq=1:me_quality=6:chroma_me:nochroma_opt:hq_ac:notrellis:lumi_mask:autoaspect:bvhq=1 -af volnorm=1 -oac mp3lame -lameopts aq=7:cbr:br=96 "/home/keith/a directory with spaces/test.wmv"
i use xterm to launch the encoding bat... could be this ?
xterm -e "path to bat/xvid/bat"
(any suggestion is appreciated!)
i am too a command line guy but my knowledge of linux isn't to much (just installed 4 month ago)
Buzz thanks for continuing to promote linux by porting more software over!
Donadagohvi (Cherokee for "Until we meet again") -
thanks freebird73717!
it's always a pleasure filling gap between windows and linux
update to 5.2 threads now work, added the possibility to specify threads
http://www.64k.it/andres/data/automen/automen52
next is to fix space issue
52 doesn't seem to work.
Code:bash-3.1$ chmod +x automen52 bash-3.1$ ./automen52 Segmentation fault
here is ok... maybe a corrupted file
try this http://www.64k.it/andres/data/automen/automen52.tar.gz
thanks!
That was quick
I can confirm that threads are working as expected for xvid, lavc-mpeg4, and x264. But not mpeg2.
For wmv, threads are enabled, but, wmv encoding (and flv) only support a single thread.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
thanks for feedback disturbed1!
update the link of first thread
update to 5.3
now path with space and file name with space will work
added queue
update to automen 6
http://www.64k.it/andres/data/automen/automen6.tar.gz
update
added a better support for dvd input
automatic crop on loading file
more deeply autocrop
added support for handbrakecli
better support for crop for dvd input
some gui layout change when users select handbrakecli
update both 32 and 64 bit version
changelog (trimmed windows only change)
some cosmetic fixes
added .mov as supported input file
fixed detection of ffh264 codec
update handbrake compatibility to 0.94
update profile.txt
better crop
better decoding of mpeg2
maybe better telecine
now automen don't hang waiting mencoder to exit
faster crop
some layout changes
better construction of batch
automen will switch to handbrake when xvid+aac in mp4 is requested
fixed framerate muxing when selectin deinterlace filter that decimate
added more tips
added recheck media with handbrake
fixed computing of dvd lenght
fixed dealing with xvid source
whenever aac audio is selected is used handbrake
added support for ffmpeg2theoraHDConvertToX, AutoMen, AutoMKV Developer -
uploaded a new build of automen
now only for 32bit
i will upload a 64bit soon
fixed CRF + 1 Pass not starting encoding
fixed missing default encoder
fixed detection of ffh264, lagarith, mjpeg, ffdivx,ffvc1 codec
update applications
fixed some layout compatibility with linux
fixed size of embedded subtitle (when reencoding from mkv and using mencoder)
added more tips
fixed detection of audio when dealing with IFO/DVD input
added detection of dvd subs
added possibility to disable multithread
fixed missing automatic output for theora output
fixed 2 pass encoding with ffmpeg2theora (missing stats declaration)
fixed use of lavf demuxer with interlaced source
added support for ffmpeg.exe encoder
added support for threads on ffmpeg
better support for evo files
added detection of OGV files
better detection with handbrakecli analysis
added tooltip
What antivirus do you use. 07/04/2009
By G)-(OST in forum ComputerReplies: 9Last Post: 6th Apr 2009, 16:50 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 21:27 -
Anyone use Automen? encode w/o subtitle?
By tofuguy in forum Video ConversionReplies: 0Last Post: 22nd Nov 2008, 17:53 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 11:23
