Forum Archive Home -> Authoring (Blu-ray) -> Author TS Stream to Blu Ray - Always need to be re-encoded?
Author TS Stream to Blu Ray - Always need to be re-encoded? | ||
| steve99999 posted 2009 Jul 11 04:53 | ||
| Hi,
I'm i missing something here? I have been thinking about getting a blu ray burner to burn HD tv to blu ray discs.Now i have the TV show recorded as a 10gb PAL TS Stream.However so far every dvd/blu ray authoring software seems to re-encode the video to a 17-18gb file.It takes about 3 hours... Is this how blu ray authoring works? If yes what is the best program to use that gives the best results after re-encoding the file? Now i know i can go down the multiAVCHD route and get ts/mkv files onto a disc without re-encoding but i want to make a proper menu etc in Vegas 9,Tmpgenc/Coral dvd 7 etc Thanks | ||
| Baldrick posted 2009 Jul 11 05:05 | ||
| Have you also tried demultiplex your ts(with for example tsmuxer) and import separate video and audio files in the authoring applications?
And is your source really blu-ray compliant? But I guess you have to wait for something like dvd-lab pro for blu-ray as I think most blu-ray authorings apps reconverts most stuff even if it's compliant. | ||
| racer-x posted 2009 Jul 11 20:45 | ||
steve99999 wrote:
Who said you can't make a proper menu using multiAVCHD? It takes a little creativity, but it's certainly doable. Here's one I did last week for a BD-9 disk authored with multiAVCHD: ![]() | ||
| zoobie posted 2009 Jul 11 23:37 | ||
| AFAIK, you can only make a static top menu in multiAVCHD at this time...the others crash. | ||
| BsMx posted 2009 Jul 12 00:41 | ||
| I can't even make a static menu in multiAVCHD cause it says something about an application not working properly | ||
| johns0 posted 2009 Jul 12 03:52 | ||
Multiavchd doesnt crash for me on any settings or menus,make sure you have all the codecs installed properly such as Avisynth 2.58,haali media splitter,ffdshow or Xvid-1.2.2 for xvid avi.
| steve99999 posted 2009 Jul 12 16:57 | ||
| Trouble is it seems you can only have 12 thumbnails per movie
I am trying to author a concert with 13 songs.So i need 13 thumbnails for the tracks and it would be a bonus if i could name each thumbnail... | ||
| johns0 posted 2009 Jul 12 22:15 | ||
| You can make a separate track for each song and name it and have thumbnails for it,not that hard to make in multiavchd. | ||
| steve99999 posted 2009 Jul 13 05:48 | ||
| What's the best software to split a ts H.264 TS file?
I have tried a few... TSSniper ProjectX TS Packet Editor But cannot get the hang of them... | ||
| steve99999 posted 2009 Jul 13 09:15 | ||
| Update...
Just used TS cutter to split the file up.Works but when i playback the tracks after authoring them.There is a slight stutter between all the tracks... Any idea whats going wrong? thanks | ||
| johns0 posted 2009 Jul 13 10:51 | ||
| Did you try tsmuxer or multiavchd to cut the file? | ||
| steve99999 posted 2009 Jul 13 13:56 | ||
| tsmuxer cuts file but the resulting files are all out of sync
Multiavchd also results in a stutter pause between each track... | ||
| mauriet posted 2009 Aug 16 06:12 | ||
| I'm stuck with the same problem.
When I burn my BDMV directory on a DVD my LG BD370 plays all individual shot seamless back without a pause. Now I want to drop some files and some files from a later SDcard. Running it through multiAVCHD give me a pause between the takes. So i tested all the original cards - burn it direct om DVD no pause. running the files through multiAVCHD and burning the originals (without altering anything!!!) between every shot a pause! What am i doing wrong? Is the a switch I'm overlooking? (In fact all I need is a index an a obj editor.) |
Login/Register to our forum to be able to post here.
