Forum archive - Anyone recognise this noise?
http://www.supermediastore.com/
Forum Archive Home -> Capturing -> Anyone recognise this noise?
DaveQB posted 2009 Oct 18 08:03
I finally have my PVR-350 capture card set up to capture some VHS tapes and I am getting this fuzz.
Its not interlacing, its more of a vertical, wave interference.
Its hard to google for it to see what filter I could use for it when capturing [or post-editing] as I do not know the name of it.
Anyone?
DaveQB posted 2009 Oct 18 08:05
Ok there is some interlacing too, but that's not my issue.
Here is the same frame after I de-interlaced it.
Might make it easier to narrow down what it is.
betwixt posted 2009 Oct 18 08:30
Looks like chroma "dot crawl". It may just be poor frequency filtering on the capture card but there are other possibilities.
Are you sure you are not mixing S-video and composite video inputs up. S video does not have the high frequency rejection feature of composite so it will let chroma carrier and possibly sound carrier signals into the video ADC.
Usually, if they are crossed over you also see a much reduced color level but that problem night be masked if you adjust the saturation control higher.
Brian
jagabo posted 2009 Oct 18 12:13
Do not use a cheap composite to s-video converter. Run composite cable straight from the VCR to the PVR-350.
http://forum.videohelp.com/topic374464.html
themaster1 posted 2009 Oct 18 13:59
faulty s-video cable or the s-video port directly (it happens on my vcr sometimes)
if not:
possibly bad grounding or antenna cable interference
lordsmurf posted 2009 Oct 18 14:56
You need a timebcase corrector to fix the waving.
There is also herringbone on the signal (or a dot crawl, hard to tell). That's often the fault of wiring or bad grounding.
DaveQB posted 2009 Oct 18 17:44
Thanks for all the info. I will investigate when I get home.
Currently I am running an S-Video to composite cable. It's a single cable, so S-Video in the PVR-350 and the other end, the composite into the Video out of the VCR.
I'll follow that link jagabo and see what I can do.
Thanks again all, I will get back to you with my findings.
Cheers.
DaveQB posted 2009 Oct 18 17:51
jagabo :
How do I do this?
http://tvcrit3.tvcrit.com/framegrab/Hauppage_pvr350_ep_bg.jpg
I only have line-in for sound and S-video.
The other proprietary S-Video like socket I thought was for output only. The cable that attaches to it has all cables marked for output [S-video, 3 composite]
DaveQB posted 2009 Oct 18 17:52
themaster1 :
if not:
I might still have a co-ax cable plugged into the VCR, laying around [touching god knows what]
I'll check tonight.
DaveQB posted 2009 Oct 18 17:54
betwixt :
Brian
I am using a cable that has S-Video [PVR-350 end] and Composite [VCR end]
jagabo posted 2009 Oct 18 18:13
DaveQB :
That's your problem. Use a straight composite cable. Cheap composite to s-video converters (like your cable) do a poor job. They do not sufficiently separate the luma and chroma causing exactly the problem you are seeing. The composite input on the PVR-350 has a comb filter to avoid that noise.
DaveQB posted 2009 Oct 18 18:44
Thanks! :)
Composite input? Where is that?
I don't believe the PVR-350 has this.
I think I might need an expensive composite-to-S-Video converter....
jagabo posted 2009 Oct 18 18:53
I didn't realize the PVR-350 didn't have a composite input (I have a 250). Are you using the composite to s-video adapter that came with the 350? Or some other adapter? If the former there should be a setting in the 350 driver that allows for composite input on the luma pin of the s-video connector. That will enable the comb filter.
The adapter that comes with the PVR-350 is not a composite to s-video converter. It doesn't try to separate luma and chroma for the s-video socket. It is simply a plug adapter for feeding composite video into the single pin that is normally used for luma on the s-video socket.
http://shspvr.com/pvr2_faq.html
DaveQB posted 2009 Oct 18 21:02
I am not where this cable came from. It could be. Its a simple, thin cable, about 30cm with a yellow composite on one end and a black S-Video on the other.
Ahhhh
http://www.wolfmanzbytes.com/pc/wintvpvr350pics/boxcontentslg.jpg
The grey adapter is what I should be using, no?
I am not using it, but I have seen it around the house.....somewhere :)
If I can not find it, are these purchasable? Or something very specific to Hauppauge?
Thanks so much for your time and effort jagabo
DaveQB posted 2009 Oct 18 21:04
PS as for driver settings, I have:
spatial_luma_filter_type (menu) : min=0 max=4 default=1 value=1
0: Off
1: 1D Horizontal
2: 1D Vertical
3: 2D H/V Separable
4: 2D Symmetric non-separable
median_luma_filter_minimum (int) : min=0 max=255 step=1 default=0 value=0 flags=inactive slider
median_luma_filter_maximum (int) : min=0 max=255 step=1 default=255 value=255 flags=inactive slider
So I guess I play with "spatial_luma_filter_type" once I get the right converter....
Thanks again!!
disturbed1 posted 2009 Oct 18 23:10
Run the Coax from the VCR to Tuner on the PVR-350. This will tell you if it is the S-Video to composite cable, or the settings on the capture card.
If the picture from the coax looks better, and you have a few VHS tapes, it might be a good decision to purchase a new VCR that has S-Video out.
DaveQB posted 2009 Oct 19 00:39
Hmmm good thinking. I thought of this initially but the capture card didn't pick up the tape play, so I guess I need to tune the card in, which I don't know how to do. What a pain, but I guess it'll be worth it if it helps narrow down the cause.
I think I have have that converter that came with it
So I have 2 avenues to try tonight.
Thanks all!
disturbed1 posted 2009 Oct 19 01:38
DaveQB :
Try changing the input and tuning to channel 3. ivtv-tune -taustralia -c03 -d/dev/video0 <--- just a guess ;)
mplayer, should be able to do this as well using mplayer tv://$OPTIONS or pvr://$OPTIONS
Abas-Avara posted 2009 Oct 19 04:56
I had just the exact same issue (the only diffrence my camcorder is the capture card) http://forum.videohelp.com/topic374464.html
The problem was solved by NOT using S-video but composite
DaveQB posted 2009 Oct 19 06:12
I could not find that adaptor :(
I did find what I thought was it and I had seen recently around the house, a PS/2 > AT adaptor. I have a feeling it won't quite do ;-)
disturbed1 I tried your idea. Set up a while loop to scan all channels. Finally found the tapes signal on ch 30.
And yes, the waving has gone. So it proves its something to do with the S-video adapter.
So how much better is Svideo to Coax?
DaveQB posted 2009 Oct 19 06:13
Abas-Avara :
Yeah your thread was linked in here, or I found it searching.
The PCR-350 only has S-Video in, so no S-Video = no capturing :(
jagabo posted 2009 Oct 19 06:43
adapter bracket for PVR-350:
http://registration.hauppauge.com/webstore/accessories2.asp?product=av_cable
If you want really good captures you need to invest about $1000 in hardware: a S-VHS deck with noise filters and line TBC, a standalone full frame TBC, and a video processing amp. Of those, the S-VHS deck is the most critical. A line TBC straightens out the scanlines (note the wavy left edge on your sample image). In addition to looking bad, all those scanlines moving left/right with every frame wastes bitrate in MPEG 2 encoding.
http://forum.videohelp.com/topic289311.html
Alternatively, look for a used Panasonic ES-10 or ES-15 DVD recorder. They have a line TBC that can be used in pass-through mode.
http://forum.videohelp.com/topic368189.html#1969469
http://forum.videohelp.com/topic369003.html#1975151
dannyboy48888 posted 2009 Oct 19 08:50
looks like a dirty head or a bad coax converter. do what the others said and hook straight s-video or comosite. the PVR-150 has these so i find it hard to believe the 350 wouldnt
DaveQB posted 2009 Oct 20 08:59
dannyboy48888 :
If it does, then I must be blind.
DaveQB posted 2009 Oct 20 09:00
I was using this type of cable initially, this gave the wave in the image that I pointed out in the initial post.
DaveQB posted 2009 Oct 20 09:01
I then bought this cable today for $14.00
But same effect. Not quite as bad, but still there and still not as good as going through coax.
So I am going to keep hunting the for the perfect S-video > composite adapter.
jagabo posted 2009 Oct 20 10:49
Those cable adapters are for converting s-video to composite. They use this simple circuit:
http://www.epanorama.net/circuits/svideo2cvideo.html
It doesn't work the other way around -- as you have found.
The adapter that comes with the PVR-350 doesn't use that circuit. It simply feeds the composite signal directly to the luma pin at the s-video input. The PVR-350 then splits the composite signal to s-video internally.
To get clean composite to s-video conversion requires active circuitry. You won't find a simple cable that does it adequately. And to get anything that does it better than the PVR-350's built in conversion will cost big bucks.
It might be possible to use those cables but convince the PVR-350 you are using the Hauppauge adapter. I wonder if you can simply cut the chroma pin off the s-video end of the cable?
Login/Register to our forum to be able to post here.
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
