Forum archive - anyone have the sumvision cyclone HD enclosure who can help with this issue
http://www.supermediastore.com/
Forum Archive Home -> Media Center PC / MediaCenters -> anyone have the sumvision cyclone HD enclosure who can help with this issue
JamesUK posted 2009 Oct 04 08:23
can you tell me, if you use the av leads, do you have to turn the drive off then back everytime you start it up?
I do on mine, i contacted the place where i got it and they said because im not using is through hd and through av, the drive had to be restarted everytime so it will revert to av, but it seems silly that i have to turn it off then on everytime.
i will quote before what their email reply was:
'Hi James
This is normal as its checking to see if you are using HDMI or AV leads.'
i replied and said ok, but they said they will find out from sumvision if there is a way around it but they dont seem to be getting back to me, does anyone here know, i cant see that it would be good for the player to be turning it on, then off then on again everytime i want to use it.
james
ocgw posted 2009 Oct 04 08:56
JamesUK :
'Hi James
james
Maybe just leave it on, how much power can it consume sitting idle?
I have couple of components that I never turn off and it doesn't hurt them
ocgw
peace
Login/Register to our forum to be able to post here.
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum Archive   RSS Feeds   Statistics
