Forum Archive Home -> Computer -> AnyDVD or AnyDVD HD
| AnyDVD or AnyDVD HD | ||
| Tbag posted 2008 Oct 03 14:39 | ||
| Hi, I have a Matshita BD-CMB UJ-120 drive on my laptop still with 4 changes region changes left but if I was to use all my changes would AnyDVD/HD be able to make it region free?
Does anyone know if it works on my drive bacause I heard some drives cant be opened/hacked or whatever its called? | ||
| hech54 posted 2008 Oct 03 15:27 | ||
| AnyDVD is not a hack so a hack and AnyDVD have nothing to do with each other.
Yes....AnyDVD will work with your laptop. There is also a free alternative that I hear works pretty well too. | ||
| Tbag posted 2008 Oct 03 15:30 | ||
| Is that for sure because I was reading that it doesn't on some Matshita drives | ||
| wtsinnc posted 2008 Oct 03 15:42 | ||
| Hello Tbag.
If I was looking on this website for software to do what you want, I might go to the Tools section and type in the word "region" in the search box. | ||
| ricoman posted 2008 Oct 03 16:00 | ||
| I have a Toshiba laptop with a Matshita drive and AnyDVD works fine with it. | ||
| Tbag posted 2008 Oct 03 16:14 | ||
| thank everyone, one more question
If I have 4 changes left and install AnyDVD then if I play a different region disk will the changes go down to 3 even though AnyDVD is installed? | ||
| Baldrick posted 2008 Oct 03 16:44 | ||
| Nope, it shouldn't change.
Try the trial! | ||
| Tbag posted 2008 Oct 03 17:14 | ||
| thanks, will do | ||
| HemLok posted 2008 Oct 17 22:08 | ||
| There are no issues with Matshita BD drives and AnyDVD HD other than the fact that Matshita drives tend to be cheap junk. BD region coding is completely different than SD DVD region coding. The drive isn't even involved when it comes to BDs region coding. You should have no problem dealing with BDs and I would advise you to not use a BD drive to do normal SD DVD stuff, anyway.
In terms of dealing with SD DVD region codes I suggest referring to an explanation given by a Slysoft developer:
Login/Register to our forum to be able to post here.
